wet / dry control knob
Started by Nikos, December 16, 2013, 11:09:37 AM
digi2t
Are you planning on using this pedal in a stereo set up? If not, I'm not quite sure why you need the blend pot. The output volume pot should suffice to balance between the effect and bypassed volume.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
Nikos
It's for mono use. Beside the volume I want to contol also the mix between dry & wet, to shape my sound. It gives you more options
mth5044
I think digi2t may have missunderstood a bit when you said 'dry vs wet'. That does sound like you want to make up the difference between the effected and dry. But you want to add a blend so you can bring in some clean signal to the effected signal.
Do a google search for the buff n blend. It should be on the Beavis Audio site. That will get you what you need.
digi2t
Ahhhh, OK, got it. Thanks for the clarification Matt.
Niko, as Matt suggested, this should do just fine;
"Effect send" will go to the BazzFuss, and the volume out of the BazzFuss will go to "Effect receive". As the schematic recommends, R4 is optional, if the BazzFuss is still too loud in the blend.
You may want to consider building everything on the same board.
Dead End FX
