Volume pedal with needless complications for fun
Started by MrStab, January 09, 2014, 12:56:54 PM
MrStab
hi guys,
at first i just wanted to make a buffer to keep my new Korg Pitchblack tuner on all the time and to allow for a killswitch of sorts (a pre-manufactured pedal! i feel dirty!), but then i thought "buffers are really boring, why not use a charge pump and a Burr Brown opamp to pimp it out?", and today i picked up a nasty, plasticky Bespeco volume pedal at the charity record shop i volunteer at, so it's all set: i'm making this pointless monstrosity.
here's what i'm after (and have built some of): two dual opamps, one for a unity-gain boost and a post-pot output buffer (as suggested here: http://www.diystompboxes.com/smfforum/index.php?topic=85422.0 ) and another "utility" opamp for tuner out and whatever else. i want this configuration in order to be able to prioritise the signal path and maybe use a lower-current IC on the tuner out opamp. in the likely event i'm not making much sense:
input > opamp A boost+opamp B tuner > volume pot > opamp A buffer > output
i thought it would all be straightforward, but then i realised:
because of the biasing difference, where should i split the input signal, if half is going to a boost and the other to a (tuner) buffer? maybe another opamp before all that, but is there any way i could avoid it? as i'd really like to keep it to just one dual opamp for boost & buffering of the signal. would splitting pre-input cap be bad?
ofc, judging by the sturdiness of this shell, expect this thread to change title to "boost pedal...!"
cheers!
Recovered guitar player.
Electronics manufacturer.
MrStab
see, most of the schematics i came across had the boost before the pot & buffer, or the boost between an input and output buffer. except this one, which uses an LDR (sourced from http://0xdfx.wordpress.com/2012/05/29/solar-lifeforce-ldr-volume-pedal-schematic/ ):
...but is buffer > pot > boost okay because that circuit uses an LDR? does it really matter if it's all unity gain (altho the option for an actual boost wouldn't go amiss)?
MrStab
it's just dawned on me that it doesn't really matter if i just use a buffer for both input & output instead of a boost,  and would probably be preferable, so consider this thread null and void. guess i need to type stuff out to fully comprehend it! lol
thanks anyway, unless someone has anything to add
brand0nized
I'm very interested in this circuit you're building! I'm currently working on building my own volume pedal shell. I'm trying to think ahead to what circuit I would use, but unfortunately, I barely know anything about building pedal circuits.
MrStab
#4
despite all the madness of my above posts, i've had the pedal up & running for about a week now and it seems fine. i just opened it up to reduce the input cap, actually, as it just wasn't offensively trebly enough.
i'd be happy to make a schematic for you, Brandon, but it's just a bunch of (probably imperfect) buffers built around an effects loop, with a volume pot at the end. and a charge pump to double the voltage. and a VU meter. and a tuner output. lol
conceptually, it's not too different from this, except without a blend control and with a volume pot: http://seanm.ca/stomp/bblender.html.
here's my build, before i added 2 more jacks to make it FX-loop-based:
brand0nized
MrStab
Quote from: brand0nized on January 15, 2014, 12:44:34 PM
Nice build, MrStab! How do the lights work?
thanks! i just used the LM3916, and the schematic on the datasheet (except just 1.2k to ground instead of a voltage divider):
http://www.ti.com/lit/ds/symlink/lm3916.pdf
leds that bright must keep your foot warm, surely.
" I will say no more "
MrStab
incidentally, we just switched to LED bulbs at my house and even the lowest available option is far too bright. i'm getting melanoma just sitting here. maybe i should just leave a guitar feedbacking into this pedal and just use that to light the place.
Quote from: MrStab on January 16, 2014, 05:36:48 AM
This brought back some fun memories. Many of those "needless complications" and a few more are inside the Visual Volume 10th Anniversary volume pedal, although implemented a bit differently.
We had a similar issue with LEDs. The first prototype had LEDs so bright that they made a blue spot on the ceiling. I had to dial that back quite a bit to avoid blinding the user looking at the volume pedal.  :icon_eek:
sunglasses help.. ;D
R.G. while your here....i have an issue with the 3916 coud you take a peek.. :)
http://www.diystompboxes.com/smfforum/index.php?topic=108853.new#new
