can anyone help with flashing rate mod for collosalus mxr clone flanger?
Started by njkmonty, February 03, 2014, 03:55:39 AM
njkmonty
ive done this on both ada clone and current lover no probs, but when running a led of  " sweep "  pot   without a current resistor, led hardly noticeable?
anyone done this mod successfully?
http://www.madbeanpedals.com/projects/Collosalus/docs/Collosalus.pdf
Fender3D
Quote from: Fender3D on November 08, 2013, 06:25:20 PM
I can't draw right now, but..
pin 7 > 10K~100K to NPN Base
Collector to +V
Emitter to 4K7 + LED to ground
The higher the base resistor the lower the op-amp loading.
njkmonty
so its a ;little more involved than just a led and limiting resistor?
npn like 2n3904
armdnrdy
Federico explained the proper way to implement a Rate LED in the circuit.
A transistor is used to drive the LED instead of the LED being driven directly from the LFO.
You can try "hanging" a current limiting resistor and an LED from pin 7 ....but you may have unintended consequences.
Using a transistor driver eliminates potential issues.
