Simple PCB for bread boarding with the FV-1 SKRM module
Started by Ice-9, February 08, 2014, 08:20:52 AM
Ice-9
A little PCB to make life easy when bread boarding the FV-1 SKRM module.
I have a couple of Franks OCT SKRM boards which have a 2x8 header on them which makes it difficult to plug straight into bread board for circuit experiments, so I thought I would do a little pcb to convert to a single line of pins to make it easy for bread boarding.
While I was doing that I thought it would be a good idea to place the control pots and 8 way switch as well for program selection and control.
so if anyone wants to use it for experimenting with the SKRM modules that Frank sells, send me a PM and I will post the files to you. (I can never seem to upload anything to the diystompboxes forum for download for some reason).
Couple of pictures
PS this PCB uses a pic for binary out code, but I am going to rework the PCB to use a few diodes with the switch instead. (cheaper and easier to build)
www.stanleyfx.co.uk
teej212
Digital Larry
Pretty clever!  I had made a couple Veroboards to hold my SKRM experiments - worked OK but splitting the copper between two rows of holes is slightly nerve wracking.  Used an Xacto knife and ohm meter to make sure.
Digital Larry
