Any cab simulator circuit worth building?
Started by emosms, February 17, 2014, 10:33:30 AM
Paul Marossy
Personally I like the ROG Condor and this old Stoned Tone Marshall cab simulator that I built a long time ago and tweaked a little bit (I use this one mostly).
caspercody
Does  anyone have the schematic for the Lionsound LS14 cab sim? I did find the schematic for the Lionsound 14.0 Dark Angel, but not sure where the cab sim starts. Thinking it is pin 5 of A1.2
Does anyone have any vero layouts for this one, or any of the ones from TrueVal, or Lart?
Rob
temol
#62
caspercody - check this thread, reply #370 (Ответ #370). There is a LS14 cabsim schematic, pcb, silkscreen. There is also kicad project available.
Vero for Lart's simple cabsim
I have TrueVAL 4x12 cabsim layout bookmarked somewhere but I cannot find it now..
edit/
There it is...  schematic - reply#31, pcb in sprint layout format - reply #42
T.
i have this on breadboard at the mo....pretty cool.  best one ive tried so far...
i added a recovery stage....still under unity though...running on 9v..
and also swapped the bottom 10 for a 50k pot...to adjust brightness.
http://www.diystompboxes.com/pedals/schems/msim.jpg
caspercody
Thanks Temol!!!!
I had to stop making PCB's, kids around and to many chances of a accident, so I am now doing vero builds. If you happen to find any vero layouts for LionSound or any TrueVal please let me know.
Deadastronaut,
I also built that Marshall cab sim, but my problem is it is too loud. Way above unity. I added a 100K volume but did not help mush in reducing the level. I need to find out how to bring the level down????
I might look at that 50K pot idea.
mine deffo isnt loud....i had to add a recovery stage after it...
i also added a switch to add caps in parallel with the 10n in the 3rd opamp...
are you running on 9v?.
caspercody
drop R2 down to reduce vol....try 4.7k  (i have, seems ok)
removed recovery stage now.....must have messed up before as it seems fine now.. :icon_rolleyes: 8)
J0K3RX
I think this is a little better representation of the Marshall sim Rob posted.
http://www.generalguitargadgets.com/wp-content/uploads/marshall_speaker_sim_sc.gif
Believe it or not, I don't think I have ever tried this one.. :icon_confused:
caspercody
That is the same one that I built. It is on the Tonepad site, and SabroTone site.
I have a very loud output, but looking at comments on SabroTone, and on here:
http://www.diystompboxes.com/smfforum/index.php?topic=104498.msg937094#msg937094
I am going to try to replace R1 and R2.
On my KMG V30 cab, I am going to try to replace the first buffer into a non-inverting amp, to give it more gain. Just need to figure out how much gain?
Willypp
I've built, and boxed that marshall one from Sabrotone.  It really nerfed my distortion for some reason, so now I'm using Lart's Simplecabsim.  Quite pleased with that one.
caspercody
I changed out R1 and R2 on the Marshall sim cab, and now I am able to lower the overall volume. This sim is really great!!!
Might try the brightness pot DA suggests.
So far I have built the Marshall sim cab, Lart Simplecab, and KMG V30. I love the Marshall the best so far.
I just need to get the volume up on the KMG V30, I just tried to convert the input IC to a non-inverting amp, but the volume was actually lower.
I had a gain of 10,001. I used 1M at R2 and a 100 ohm at R1. Maybe I am not doing it correctly. I had sound just really low in volume.
anotherjim
KMG V30, that IC1b input is a unity gain non-inverting buffer. To give it some gain, leave R1 as it is and replace the feedback wire from pin 6 to 7 by a network like  IC1c has with R6, R7, C4.
caspercody
Rob,
Are you referring to the input cap value by samhays (reply #14)?
anotherjim,
Thanks, I will try that tonight.
Rob
yes,  input cap 4.7n...input resistor 220k, and feedback resistor 220k....
and 4.7n cap out....
i have 2 on/off/on toggles for putting caps in parallel with the existing caps on opamp 3/4...
just gives more 'tonal' options as it can be a tad bright..
I have used the Marshall cabsim a la Tonepad, GGG, etc. and have been pleased with the results. Definitely way loud, but I usually just throw a volume control after it.
I'm really interested now to check out the Hotline 2 as I have now heard too many praising reviews to ignore :P Unfortunately Russian websites tend to be blocked on our work network (surprise ::)) so I won't be able to look at it until I get home.
caspercody
Vigilante397
Check out reply 54 on this tread
caspercody
Ah, excellent, thanks Rob! :) I must have missed that when my slow internet connection wasn't loading the pictures and I was skimming through the thread.
