latest hairbrain half baked idea... could use some thoughts.. a fuzz phaser
Started by pinkjimiphoton, February 17, 2014, 01:33:13 PM
blackieNYC
This thread gets the hamster-wheel spinning.  Don't know if this would cut it for you but I'm certainly goin to give this a go:
I mentioned earlier my stereo (in and out) panner that I have slowly sweeping between two pedals ( or pedal chains!).  A slow sweep. I have another stereo panner I could put downstream, on one leg only, so fuzz A would sweep over to the other leg where fuzzes B and C are sweeping back and forth. All mixed back to mono. Three stereo panners at slightly different rates would give you sweeps between every possible combination of fuzzes ABC&D.  Ex. Just as A is morphing into B, the 1st panner swings slowly over to catch some morph moment between C and D.  Maybe just C and no D this particular time around. All four fuzzes - eventually you would hear every possible combination of morphing.
pinkjimiphoton
blackie... please document this with video,
i'll make the popcorn and the beer ;)
Slava Ukraini!
~Jack Darr
