Shoegazer was working until I moved to a new enclosure
Started by pulsewidthmod, February 21, 2014, 11:30:48 AM
pulsewidthmod
Ok, so I built the Devi Ever Shoegazer last year, got it working. Decided to put in a smaller enclosure. Rewired everything to make it neater (however at this point it's not so neat anymore.
Basically it works, but it's as if the gate is always open (so there is a constant fuzz sound on both effects.)
Here's the schematics: http://imgur.com/LQq1C5f,BkTXTMN,DcADvNQ,ua218Rc,ZNmx9wo
http://imgur.com/LQq1C5f,BkTXTMN,DcADvNQ,ua218Rc,ZNmx9wo#1
http://imgur.com/LQq1C5f,BkTXTMN,DcADvNQ,ua218Rc,ZNmx9wo#2
http://imgur.com/LQq1C5f,BkTXTMN,DcADvNQ,ua218Rc,ZNmx9wo#3
http://imgur.com/LQq1C5f,BkTXTMN,DcADvNQ,ua218Rc,ZNmx9wo#4
Here's the voltage readings off of the transistors:
Soda Meiser:
Q1 c=0 b=0 e=1.0
Q2 c=0 b=0 e=1.04
Q3 c=0 b=0 e=1.01
Q4 c=0 b=0 e=9.4
Torn's Peaker:
Q1 c=.58 b=.96 e=.59
Q2 c=0 b=.59 e=.96
Q3 c=0 b=0 e=.14
Q4 c=13 b=.04 e=0
I'm not sure if I measured these correctly. I am working on uploading a video right now of what the pedal is doing.
chick ... geek ...& synth freak
https://twitter.com/pulsewidthmod
pulsewidthmod
knutolai
Im no good with transistors, but I'd say there is something very wrong with the voltages of the Soda Meiser. Are you sure you did the measuring correctly? Also It would be helpful if you labeled the transistors in the schematics (Which one is Q1, 2, 3... ).
pulsewidthmod
the pedal is working and i think i got the trannies measured backwards ... but yeah, the pedal is working.
rousejeremy
 I would say go over every little thing you changed comparing each individual part with the layout. It worked once, so whatever you changed when you moved it to another enclosure is the problem.
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
pulsewidthmod
Hey, thank you ... the pedal is fine. There was a ground issue. The pedal is working great now. If only I could find all the screws i set aside for all my enclosures, I'd be set ;)
