Any use for a 2N6520 PNP?
Started by Will.mendil, February 28, 2014, 05:14:51 PM
italianguy63
I think it is pretty much "run what ya' brung..." i.e. try anything and see how it sounds--
I play only with PNP Ge's.. I've used:  AC128, 2N404, 2N404A, 2N508, 2N1305, 2N1309, NTE126, NTE126A, GT308B (Russian), GT308V (Russian).  Also, favorites are OC44, AC188, AC125, SFT308, NKT's, et. al.
Get hunting!
LucifersTrip
Quote from: Will.mendil on March 05, 2014, 04:28:17 PM
When you say minimal tweaking. What are you thinkin about?
small tweak of biasing resistors...which you should experiment with anyway, regardless of the hfe or transistor
always think outside the box
Will.mendil
Oh yeah. That's pretty easy. I am actually making my first NPN fuzz on which you can select between 8 trans 4 for each so I had to has the bias knob on it. Makes it easier.
Don't know what to do with a paritculare transistor? Check this website where stompbox pedals are listed by what transistors they use
http://scfxguide.wordpress.com/
