Any use for a 2N6520 PNP?
Started by Will.mendil, February 28, 2014, 05:14:51 PM
italianguy63
Sent.  If you use the spreadsheet I sent you-- just get the resistors "close."  Input the actual values into the formula.  The spreadsheet does all the math.
MC
Will.mendil
Got it. That was quick thanks! Do I follow the circuit from my previous post?
Don't know what to do with a paritculare transistor? Check this website where stompbox pedals are listed by what transistors they use
http://scfxguide.wordpress.com/
italianguy63
Yes.  That is what I use too.
I cant remember but i think i either tested the resistor with the DMM or put in a trimmer (5k) and wired it as a variable resister then set with the DMM.
Will.mendil
I only got a small 10k. Guess it ll have to do. I'll try it now and see how it goes.
Will.mendil
Ok got it to work. Tough circuit :p I got 75 and 83 hFE what does that tell you? Am I looking for more or less
Will.mendil
Will.mendil
Everyone gone to sleep already?:p
italianguy63
Will--
It just depends.  You need to see what you are building, and research what you need.  Some circuits want high Hfe, while others want low Hfe.  Some want no leakage, where others need some.  Regardless-- any Germanium with leakage above 300 should just probably get tossed in the trash as it is probably near failure.
As an example-- if you are building a Fuzz Face (as I usually am).  The magic Q1 value is around 70 to 85 Hfe.  And, for Q2 you need more gain-- like 110 to even 140 Hfe.
Anyway, from my experience -- 85 Hfe is a good #.  Very much in the middle.  I've seen ranges from low 30's to about 250's.  Most in the 50's to 60's (for the part#'s I select).  It depends on the particular part # too.  Anyway-- consult a transistor spec. sheet for the ranges.  Then, test them because Germanium (actual vs. specification) are all over the place.
MC
Will.mendil
Might not have been clear but 2n6520 is silicon isn't it?
Do you java examples of odd exotic pedals that could use this as the fuzz face is a bit done over and over again. I got a pretty good sounding fuzz on its way. So I'm more looking for old vintage "hybrids" in which a 2n6520 could substitute
italianguy63
I'm sorry, I don't know.  I live in my own little niche.  I almost exclusively play with fuzzes with Germaniums.  I hunt down Germaniums, test um, and use um...
Maybe someone else here with more knowledge can chime in...
Will.mendil
Well in that case. Test question. Where to get relatively cheap ge transistors that could be shipped to Europe without the out stating postal fee
Will.mendil
italianguy63
I guess eBay unless someone else here may have specific vendors over there.  I personally have gotten a big bunch of Russian surplus Germaniums from Russia, and also some very nice GE 128's from E. Europe...
LucifersTrip
Quote from: Will.mendil on March 04, 2014, 05:09:03 AM
yes...and 85 seems good, right in the Hfe 20/100 range.
http://transistor-spravochnik.ru/description/2n6520/5969
just pick a vintage silicon fuzz and these will most likely work with minimal tweaking...Fuzz Rite definitely or even a SuperFuzz or Big Muff (I've done all 3 with hfe <100).   A more obscure one would be the Sunn Buzz, which is a favorite...a Jen Fuzz, Knight Fuzz, 1 of the 2 transistors in a Heathkit Fuzz or Jordan Bosstone, Astrotone, etc..
http://www.luciferstrip.com/fuzz/sunnbuzz-schematic.jpg
really, there's just too many vintage si fuzzes that can be built with those
always think outside the box
Will.mendil
It doesn't have to be a fuzz :). But thanks  I'll check them out
Will.mendil
When you say minimal tweaking. What are you thinkin about?
Quote from: Will.mendil on March 04, 2014, 05:19:23 AM
Check out alexer1 (Ukraine) and minifux1 (Germany) on the Bay.  I've used both.  Prices can be fairly reasonable.
italianguy63
I got some nice AC128's from eBay "elebcz" (Czech Rep.)-- but haven't had a chance to try them yet.  But, the #'s were right.
Will.mendil
Cool. Last noob question, which ge transistor should I be looking for , apparte from ac128?
