Can Feedback loop soft clipping be done with a discrete transistor stage?
Started by midwayfair, March 03, 2014, 10:54:41 AM
midwayfair
I was wondering if it's possible to do soft clipping like a pair of diodes in the feedback loop of an op amp, but with a transistor stage. Putting them in the positive feedback loop (base-collector) is still just hard clipping.
I was positing that perhaps it could be done with a Fuzz Face style arrangement, where the 100K between the base of Q1 and emitter of Q2 is a pair of diodes. Some other biasing would need to be worked out to turn on Q1.
I know, I know, just use op amps. I can't help it, I like transistors. :P
tca
Yes:
http://www.muzique.com/schem/projects.htm
Just put two diodes in the feedback loop.
Cheers.
midwayfair
I'm pretty sure I've read that that's hard clipping, as I mentioned in my first paragraph.
tca
^ It looks soft and sounds like soft :)
P.S.
New image.
midwayfair
thelonious
I wonder if the series resistor trick would soften it even more. (I've never been quite clear on whether that only works in hard clipping situations, or if in a feedback loop it would still soften the transition itself even though it's limiting overall feedback.)
tca
Edit picture above. The lower plot shows what happens when R6 varies from 1k to 100k.
Cheers.
midwayfair
Quote from: tca on March 03, 2014, 12:28:36 PM
Cheers.
That's interesting. Why does that happen (becomes more asymmetric)?
tca
That is because the way the transistor is biased. Take a look. When you increase the value of the resistor, the diodes contribute less and less to the feedback.
Look at the next picture (no diodes).
Cheers.
DougH
Lurco
Quote from: midwayfair on March 03, 2014, 10:54:41 AM
C-to-B is NEGATIVE feedback.
midwayfair
Quote from: Gus on March 03, 2014, 07:24:08 PM
Have you seen this thread?
http://www.diystompboxes.com/smfforum/index.php?topic=104029.20
reply 29, look at the 2nd gain stage
Thanks, I did see that one.
Smallbear's Ursa overdrive uses the same feedback loop arrangement; I even used it in my Mossy Sloth fuzz (with a MOSFET) -- I just didn't realize it was softclipping.
Quote from: midwayfair on March 03, 2014, 09:08:10 PM
... I just didn't realize it was softclipping.
What's in a name? that which we call a rose
By any other name would smell as sweet;
William Shakespeare, between 1591 and 1595
MaxPower
What lies behind us and what lies before us are tiny matters, compared to what lies within us - Emerson
pappasmurfsharem
Gus
Not really, look closer at the ASDF and tca posts note the added series resistor and how the waveforms change
Also the cap that is in series with the diodes value matters and the cap value from C to B(if used)
The BMP uses this clipping with out the added series resistor
The bluesbreaker has series resistance with the diode clipping
US patent 3,223,936  has diodes from C to B.
I believe I understand the point R.G. is making with the post, however the adding of a series resistor to the diodes makes a difference
merlinb
Apparently the ubiquitous LM317 will behave as a very soft diode if the OUT and ADJ pins are shorted. I wonder what it would sound like in a clipping stage?
http://www.edn.com/design/analog/4422122/Power-Zener-using-the-LM317
samhay
Quote from: merlinb on March 04, 2014, 07:22:01 AM
I was playing with an LM317 as an amplifier a couple of weeks ago. Not sure if I tried that though. Perhaps we should start a new thread.
midwayfair
Quote from: samhay on March 04, 2014, 08:00:36 AM
Or revive the "pleasant distortion without clipping" thread, which had a bunch of soft clipping discussion. http://www.diystompboxes.com/smfforum/index.php?topic=103129.0
Fig. 3 here looks intriguing, but I don't know if it was exactly what I had in mind when I said "soft clipping using a transistor" ... http://diale.org/img/soft_clippling.png
