X FUZZ
Started by deadastronaut, March 14, 2014, 06:51:37 AM
Domin
Somehow PCB is working and sound is sweet, but bias is homehow weird but ill let it be how it is :) Its pity I cant send audio
Domin
your welcome, enjoy.... 8)
11-90-an
you *can* send audio by recording it and putting it in youtube, soundcloud or other sites, then type in the link here... :icon_wink:
flip flop flip flop flip
Domin
Ok, if I record something decent (I dont have amp right now, so I recorded just thru Vox Amplug and putting headphones next to mic of my phone), I'll send it :)
if you need a good little amp that takes pedals well , search ''punch amp'' or ''chime amp''
your next build...  ;)
http://guitar-fx-layouts.42897.x6.nabble.com/Chime-Amp-Punch-Amp-v-2-td8493.html
Domin
I have amp, but 20W Ampeg :D And now I dont have it nearby, and I have bass, so Punch amp or Chime amp wont work so well I think :) Only if I plug 10" speaker into it :D But thanks for a tip :)
ahh gotya..thought you didnt have an amp at all... ;)
Domin
Its good that Ampeg and I have that Vox Amplug Bass 2, but I'm thinking about some tube preamp running on 9V...
Domin
Its boxed, just in plastic box, but should be ok :) And I didnt use true bypass but this style of switching, but with DPDT switch and Im switching battery with it too...
Domin
#432
Is normal that diodes are glowing when I turn it on?
Theres schematic how its connected...
It happens only when I turn pot to one side
A couple of things...
1. I wouldn't really expect to see much light from the LEDs - certainly not as bright as your picture shows.  For them both to be lit at the same time suggests one is round the wrong way.
2. Switching power with the bypass stomp-switch is not a good idea.  Particularly in the middle of a song.
3. A plastic box means you'll pick up radio stations, microwaves and WiFi.
4. Your switching scheme means the circuit is constantly sucking at your guitar signal.
If you can't get hold of a 3PDT switch, check out R.G.'s Millennium switching system (at the GeoFEX link above).  And use one of the common schemes for wiring jacks and batteries so that power is switched on when you insert your guitar lead.  I use the ones at Tonepad all the time.
Domin
And if I just use DPDT as a true bypass and separate switch for battery?
Domin
#435
I made it with 2 switches and same problem, but I dont know if LEDs are lightning up when I turn up wolume or turn down
Use a stereo input jack and wire the black battery lead to the ring lug.  With no guitar lead inserted, it's not connected to anything and the battery doesn't drain.  Put the (mono) guitar lead in, and the ring and sleeve lugs are shorted by the plug, thereby connecting the battery -ve to ground and completing the circuit.
Domin
I dont have stereo jack :( Isnt using switch same thing? Look at this video and you'll see what is problem
https://youtu.be/Ql0u2E7ZG2A
When I turn battery on, its ok, when I touch pot with finger they light up, but when I touch battery they dont light...
deadmandance
Does anyone have a vero layout for this version? Wanted to give it a try, but I only got stripboard with me
Quote from: Jdansti on July 08, 2014, 04:15:31 PM
Here's my corrected layout:
Domin
Can somebody tell me opinion to this? I want to put it as a onboard effect...Its like boost/fuzz, with switch I can sellect between first stage or second stage of 2 transistor XFuzz...
