3PDT Dual FX Loop...
Started by mg.audio, April 06, 2014, 04:56:44 AM
mg.audio
I am building a Dual FX loop box and I would like to make it work using 3-pole stomp switches for both bypass and A/B functions. Here's a schematic, excluding the bypass section and saving one pole of the stomp switch for LEDs:
The bypass section is just going to be a typical 3PDT true bypass, in which the input of the FX loop is grounded in bypass mode.
My question is this: does hard-wiring the return jacks together like this pose any impedance or noise (or other) problems? (I'm guessing that depends on what goes in the loops.)
tommycataus
I have built one of these for my friend (I think it's the same) and he's had no problems so far.
http://i1015.photobucket.com/albums/af272/tomw_aus/Untitled_zps21a9a941.png
http://i1015.photobucket.com/albums/af272/tomw_aus/ABFXLoop_zps738b6f82.png
It didn't look quite as messy in real life as the version in paint, but I'm not great with schematics! Hope this helps.
"Remember, there's a big difference between kneeling down and bending over." - FZ
Two returns symply Y-ed together "may" fight each other.
Ben N
#3
You have an extra pole, why not use it to select a return? Or, in the alternative, put in mixing resistors, or a simple virtual ground mixer.
mg.audio
Quote from: tommycataus on April 06, 2014, 05:39:44 AM
Tommy - your schematic is different in two ways, 1: You have both pairs of send and return jacks wired to the switch, therefore you won't have any issues with the loops interfering with each other. 2: I want the input of the bypassed loop to be grounded, to avoid switch popping and reduce noise. Has your friend reported any popping when selecting between the two loops?
Quote from: PRR on April 06, 2014, 05:27:06 PM
Yep, and I can think of two ways this would happen; either the output of the "bypassed" effect loads down the signal coming from the active loop OR there's the possibility of the noise floor of effects in the "bypassed" loop being added to the active loop. I would think grounding the input fixes the noise problem unless, perhaps, there is a noisy pedal like a heavy metal distortion or a DOD Gonkulator in the loop. This may not be an issue for the guy who will be using it (hottest pedal he's got is a Keeley-modded RAT as far as I know).
Let me say it clearer: two outputs shorted together WILL fight.
In some cases they may "mix", but the one with the lower output impedance dominates the mix.
In cases where opamp outputs face each other, with different signals, the output will be gross distortion and hot chips.
The hiss question is less interesting (because results will be unsatisfactory for reasons above). But note that many boxes hiss even when their inputs are shorted.
If you made it for me, and I found that you had hard-shorted two of my precious devices' outputs to each other, I'd be upset.
electrosonic
Doesn't ground the unused loop, I don't see an easy way to do that without adding an active device.
