mc1741 metal can pinout
Started by Kipper4, April 15, 2014, 01:55:07 PM
mc1741 cg 8218 to be precise
i found an unreadable pdf for this part on google.
Intended use GGG IC buffer.
Does anyone have a legible copy please. or else can point me on the right road to reading the pinouts using some kind of common convention found in metal can ICs.
I'm a metal can IC virgin. It was a present from a good buddy and fellow forumite.
thanks D.S.
Rich
Govmnt_Lacky
Set the IC on its legs on a table top. Look DOWN on it from above the can.
The leg that is directly under the little metal tab is Pin 8. They number downward as you go clockwise.
You can definitely space the legs appropriately to fit this into a typical 8-pin DIP socket without leg twisting  ;)
Thanks.
Giving it a go now in my socket.
Another Tid bit for the book.
Edit
Yep thats the one cheers mate.
