Boss DS-1 troubleshooting
Started by Renegadrian, April 27, 2014, 10:47:32 AM
Renegadrian
Hi there, I just got a DS-1 on repair...M5223AL inside...
voltage diode war burnt, changed it but no changes, led lits but no sound...what should I check!? transistor, M5223AL?!
armdnrdy
Renegadrian
#2
THX Larry
according to the schem I have all the right voltages...
battery            9.02
r2              4.48
q1 C                 9.02
r4              4.48
r5                     4.48
r8                     9.02
r10                   4.48
m5112al pin 8   9.02
d4-d5               4.48
r19-r20             4.48
q3 C                 9.02
c23                   9.02
r24-r25            4.48
d2               9.02
r30-r31       4.48
R36               9.02
armdnrdy
Do you get bypassed signal bypass with the switch?
If so, I would audio probe the circuit to find where the signal stops.
If you had to replace the diode, that sounds like someone plugged in the wrong power supply and "toasted" a component.
GibsonGM
Maybe a switching FET?  Just a really dumb guess since the Boss switching is kind of Greek to many.   +1,000 on the audio probe.
Renegadrian
Yeah I think that one of these components toasted...I'll audio probe tomorrow...thx for now...
GibsonGM
R.G. has an article on the switching at GEOFEX....one of these days I'll get one to work, never could when I tried to DIY one.
Renegadrian
UPDATE: Audio probed it, the signal stops at pin 3 of the M5223AL, which is the input, it should exit from pin 1 but no signal...Guess it's the SIP then...
armdnrdy
So you have signal at the input of U1A? (Pin 3, R39, D8)
Check that D8 is good.
Renegadrian
changed d8, still the same, no sound from the chip output
armdnrdy
Well...It looks like you need to replace the op amp.
If you can't find a M5223AL, you can make a daughter board for a replacement. Look through this thread for some op amp ideas.
http://www.diystompboxes.com/smfforum/index.php?topic=66209.0;wap2
Renegadrian
it seems there are some on aliexpress. I'll take one there...
Renegadrian
I bought the chip on aliexpress, 3 weeks wait...new chip new life...
another ds-1 got the chip burned, I built a small adapter and put a tl062 in it, not bad.
