Help with board for SMPS
Started by george79, May 09, 2014, 06:49:57 PM
Metaldestroyer
It would be cool if someone would do really nice boards for both the NE555 and MAX1771 SMPS's and share them on OshPark so us normal beings could just order a few whenever we want.
george79
the problem is that i get a buzzing sound from the IRF.I cant adjust the output voltage and the IRF overheat very quick.I have 400v at output without load.Thats the third SMPS that i build and i cant think the problem.The other two are dead silent and working continous for 2-3 hours without problem.My head is gona blow.Any help please welcome!!
i have use the JOK3RS board previous posted all the time
J0K3RX
I found a mistake with my board layout from before, not sure if it will cause this problem you are having? I had a break in the ground plane.. stupid mistake :icon_rolleyes: But, I have since fixed it and re-uploaded it to the original post. If the board you are using this time is the old one I uploaded before you can easily fix it if you take a look.. You can run a jumper or put a solder bridge across it. The old one may work fine in some cases depending on how you have it wired but, it also may cause noise, hum..
Fixed
J0K3RX
Quote from: Metaldestroyer on October 16, 2015, 01:21:23 PM
That's a great idea! I'm good for at least 3 or 4.. I need them ASAP and they must be "really nice" or, I may not be able to use them! When do you think you will be done?     :icon_neutral:
By the way, if you do a little diggin you will find the Eagle files for both the 555 and 1771 which you can then use to create gerbers, upload to OSH Park and order your own boards.   :icon_wink:  Remember "necessity is the mother of figurin sh!t out fer yerself" and I think somebody really smart like Playdoh said that...!   ???
george79
ok,problem solved.
i have printed the old pcb.have them in stock.simple i used a jumper to connect the to grounds together.OR connect the to ground wires together.Working!!!
J0K3RX
First, there is this post here on DIYSB
http://www.diystompboxes.com/smfforum/index.php?topic=79736.0
There is this site with some serious effort put into the design based around the MAX1771
http://desmith.net/NMdS/Electronics/NixiePSU.html   < --- Eagle files are available for download.
http://www.tayloredge.com/storefront/SmartNixie/PSU/comparison.html   < --- Quick and easy already built and ready to go.
http://oseq.org/shop/   < --- DeXTeR/Gabriel Tudoran - He is the GTFO God who freely shares his designs with us mortals here on the DIYSB forum..  :icon_lol: Dude is a true asset to this forum and an Awesome person!
http://www.diystompboxes.com/smfforum/index.php?topic=93936.0
http://www.diystompboxes.com/smfforum/index.php?topic=111758.0
J0K3RX
Quote from: george79 on October 17, 2015, 10:03:41 AM
ok,problem solved.
Glad you figured it out! Sorry bout that  :icon_rolleyes:
tubegeek
Quote from: J0K3RX on October 17, 2015, 10:36:19 AMSorry bout that  :icon_rolleyes:
Apologies are nice, but how much are you going to refund him?
J0K3RX
Quote from: tubegeek on October 18, 2015, 10:41:25 AM
Hmm.. Let me figure this out/ No pictures x No sound demo = 0 refund   ;)
