TREMMY TREMOLO
Started by deadastronaut, May 11, 2014, 03:46:45 PM
Quote from: deadastronaut on May 31, 2014, 06:45:28 PM
ok, got my 2 lfo's going...
Blimey!  Get thee to a synth forum!   :icon_eek:   Then let us know where you land and we'll all follow.    :icon_biggrin:
^ funny, i have been looking at a load of synth stuff lately.....inevitable i guess. :)
anyway, swapped the lfo's over...clip.
https://dl.dropboxusercontent.com/u/7464107/filtertremmy9.mp3
i quite like the filter, but i may as well just stick a phaser/ms20/flanger after it and be done with it  really...good fun though.. 8)
John Lyons
Nice work Rob, it sounds fantastic.
Basic Audio Pedals
www.basicaudio.net/
Quote from: deadastronaut on June 01, 2014, 05:24:01 PM
Ha ha - yeah, me too!   ;D   Knowing my unstoppable GAS, I feel a visit over to Rick's emporium to pick up some modules is inevitable...   :icon_rolleyes:
haveyouseenhim
Quote from: bluebunny on June 02, 2014, 03:35:10 AM
Don't forget the two year shipping time...                      :icon_mrgreen:
http://www.youtube.com/haveyouseenhim89
I'm sorry sir, we only have the regular ohms.
cheers john: 8)
@mike...now now..you know these things take time... ;D
i stuck a keyboard through this too last night...pretty cool, especially on pads, drones etc... 8)
Quote from: deadastronaut on June 02, 2014, 05:57:33 AM
Damn your eyes, Rob!  Now I'll have to build one of these into a Eurorack module!   :icon_eek:                                                          ;)
nocentelli
Sounds great, beautiful playing too. So is it tremolo->filter? Any chance of posting the schem from that lsst clip?
hi leo, its basically this:
http://www.diystompboxes.com/smfforum/index.php?topic=107197.msg975196#msg975196
with 2 of these lfo's.(bottom schemo) ..but only one lfo has the square/triangle switching...which is for the trem side of things....other lfo for filter..
http://www.diystompboxes.com/smfforum/index.php?topic=107197.msg975091#msg975091
had to move the filter on off switch to the pin 1 side of the opamp, otherwise i get  bleed through when off...(note to self really )
i'm tweaking the filter to be at a better 'unity' tonal wise when using distortion...its all fine when clean, but adding distortion is a little lower really...tweak tweak..
i also had it working just as well with removing the top 'T' entirely... so it was just the 470k and 2x 2.2nf's>ldr..
ok, had a few tweaks here n there....
mainly i found using super green led for the ldrs gave the best sweeps...and used yellow diffused for the indicators to avoid blindness..(which work together nicely)
i also removed the upper/lower half of the twin t filter, which gives me a fuller filter sound which goes much better with a distortion,
i added a pot there instead which gives me a depth/Q control too..very cool. and adjusted the lfo to suit..
like i said i shifted the filter swtch to the right (pin1) of the opamp, otherwise i had bleed through when off....behaves nicely now...
i still hate the trem depth control though, ive tried sticking a 1k across the 1k pot, and reversing the pot  but its still bunched up....needs attention imo..
this is where i am so far,
Another cool project.  Nice one, Rob.   8)
Quote from: deadastronaut on June 05, 2014, 08:34:25 AM
. . .used yellow diffused for the indicators to avoid blindness
Unlike this one of mine!   ;D
^ funny i just got an appointment letter from specsavers...must be an omen. :icon_evil:
hey rob.
something to try led driving wise. remove R25 (Anode now to pin 7), shift the pin 6 wire to top of R24, maybe increase R24. this may blow everything up, I dunno, worth a try if you're still on the bb. the driving method is working for my envelope this end.
and the green led on the depth pot: is that ON - going OFF-er with the lfo, or is it OFF- turned on-er by lfo?
cheers DA,  ive had a few tweaks , ok got the freq's sorted on the filter with distortion....this is twiddling with the filter/ldr Q pot.
still need to sort the depth out without altering the freq though....little steps... ::)
i'm having a hawkwind flashback morning...(with the choppy trem added you can get a great spirit of the age thing going..really authentic sound) 8)
https://dl.dropboxusercontent.com/u/7464107/tremshifterQ.mp3
Quote from: deadastronaut on June 06, 2014, 04:01:50 AM
"The Hawkwind".  That's what I'll be calling mine, when I build it...   ;)
that's the spirit.....erm.....of the age.. ;D
coats on... ::)
but before i step outside, i was thinking...yeah i know right ::)
but as i'm switching this filter in/out, i may as wel be a greedy little bugger and  switch between 2 filters too...bright/warmer - thin/fat..
on/off/on switch :icon_idea: 8) may as well while i'm at it..only a couple more bits 8)
Next, you'll be wanting a third LFO to morph between two filters.
Oh no!  What have I said?!   :o
samhay
#118
Sounds cool Rob.
^still need to sort the depth out without altering the freq though.
At the moment, as you turn down the depth, you shift the filter towards the treble.
Try putting a C100k depth pot in series with the 2n2 caps in the filter. As you add resistance, you reduce the peak and add a shelf, which flattens it out.
Edit - and I would imagine the filter might sound fuller with 4n7 caps insteady of 2n2.
cheers sam, yep i tried that last night with a 100k (trim) i haven't got a C POT though..
it works, but i get a whooooshhhhh over the top still too...(which may be unavoidable with a dirt pedal on it i guess )
edit: yeah i tried different caps, fatter/thinner, that's what i was saying about switching them too... 8)
