electro harmonix graphic fuzz schematic request
Started by beatnik, May 13, 2014, 10:39:01 AM
beatnik
hi guys, i want to modify the power supply of my graphic fuzz
i can't find the schematic of the pedal, all threads in the forum have dead links
anybody has that?
Mac Walker
beatnik
thank you very much
i was thinking to add a 79L12 regulator to obtain -12V
i would power the pedal with a 18V DC power supply
do you see any inconvenience? maybe 18V is too much for 12V regulators?
anchovie
A negative voltage regulator doesn't turn a positive voltage into a negative one - it's for regulating voltages that are already negative.
beatnik
right now i see. should use AC supply instead! thanks
so at this point i don't think is worth modifying the circuit, since i would have to use a separate power supply anyway
but also i am thinking that maybe that power supply design is not the best? that 40V with those big resistor seem overkill
do you have any suggestion?
What is wrong with it?
It *IS* very strange. But it does give good regulated +/-12V at MINIMUM cost. The resistors throw about 1.3 Watts, but all power supplies have "some" waste. Next to your 50 Watt (even a 5 Watt) amplifier, the "waste" here is trivial.
And it works (right?).
beatnik
well, i was thinking maybe the resistor dissipate too much heat on the circuit board?
