Quiz about a mosfet booster
Started by tca, May 13, 2014, 10:54:40 AM
bool
For the "treble cut" problem, you can "darlington" the mosfet, either with a simple bjt or a small-signal mosfet with lesser gate cap. However, it isn't always "proper" to connect the drains of the small-sig and "the beefy one" together. Imho better is to connect the drain/collector of the small-sig directly to the V+, but thru a current-limiting resistor. Which means that the V+ should be fairly clean to begin with...
Of course, all of this experimentation should be done within the context of the desired tonal character...
tca
Quote from: bool on May 21, 2014, 06:34:19 AM
You are right, but the distortion you get out of it is completely different of that of a single device stage ac coupled (with a capacitor) to a buffer.
bool
within the tonal context of a booster it probably shouldn't be that bad, but for an guitar od you are right...
