3 Channel guitar preamp
Started by gtudoran, May 23, 2014, 05:06:10 AM
gtudoran
Hey guys, this is my latest build. A 3 channel guitar preamp. Main features:
- 3 switchable channels (it can be done MIDI compatible);
- Separate EQ and Gain/Volume controls for Clean / Crunch-Lead
- preamp schematic https://dl.dropboxusercontent.com/u/15275178/Preamp_Rack/PREAMP_SCH.pdf
- hv psu schematic https://dl.dropboxusercontent.com/u/15275178/Preamp_Rack/HV_PSU_SCH.pdf
- pcb transfer for both of them https://dl.dropboxusercontent.com/u/15275178/Preamp_Rack/PREAMP_PCB.pdf  https://dl.dropboxusercontent.com/u/15275178/Preamp_Rack/HV_PSU_PCB.pdf
- topsilk for both of them https://dl.dropboxusercontent.com/u/15275178/Preamp_Rack/HV_PSU_TOPSILK.pdf  https://dl.dropboxusercontent.com/u/15275178/Preamp_Rack/PREAMP_TOPSILK.pdf
Any question will be answered :)
Best regards,
Gabriel Tudoran
Analog Sound
PS: the PSU requires a Xformer with this data: primary 120 or 220v, secondary: 6.3v @ 1.2A and 190-0-190 @ 20mA
PPS: the switching mode is one of your choice (you can use relays or you can use switches), the lead channel use all triodes form the top
Pictures:
tca
gtudoran
#2
A small sample: clean and drive
@tca: https://soundcloud.com/analog-sound/tubepreamp
Sorry for my sloppy guitar skills.
Best regards
Gabriel Tudoran
Analog Sound
tca
Gus
Looks like you are loading the first tube with a tone control/volume circuit and a 470k with a 180K plate resistor?
J0K3RX
gtudoran
The decoupling caps from the cathodes are not missing. As you can see, i've put one on every stage. They are not necessary, you can tweak according to your taste (1u  to 2.2u will be more the ok).
Regarding the first tube: @Gus can you continue with the idea :D  i didn't notice any problems.
Best regards,
Gabriel Tudoran
Analog Sound
gtudoran
#7
General request; some guts pictures.
Best regards,
Gabriel Tudoran
Analog Sound
fastbreak78
Man, that's sounds fantastic! If you think your playing is sloppy, gtudoran, then you may have never heard mine!  :icon_wink:
"You miss 100% of the shots you don't take." ~ Wayne Gretzky
"Every strike brings me closer to the next home run." ~ Babe Ruth
