Inductorless wah modification
Started by gasmask, May 26, 2014, 02:42:02 AM
gasmask
I've recently bought a breadboard ( finally ). I always wanted to have wahwah pedal but it's too expensive to buy original ones. I breadboarded inductorless wah by beavis audio (http://www.beavisaudio.com/Projects/ColorsoundWah/index.htm).
It sounds good but I wasn't satisfied. My mods:
1. To increase the level of pedal I changed 330Kohm resistor to 100K. I removed 47kohm, 100Kohm and 2.2nF in main signal path. It just changed into a simple booster.
2. Some people on this forum said that it will be better to make both capacitors in bottom T part equal. So I made both 2.2nF.
3. According to some other schematics, I have changed 33Kohm resistor before wah pot to 360ohm.
4. Changed 15nF to 6.8nF. Sounds better. In next week I will try with other values from 2.2nF to 27nF.
Now my schematic:
http://www.mediafire.com/view/5j5dx58c1dsoj8j/wah_schematic.jpg
I will include the soundclips later.  ;)
Gasmask
gasmask
Soundclip (I haven't got enclosure for this pedal so I change position of wahpot with my hand) : http://www.mediafire.com/listen/lvffhdl1m9duhzv/inductorless_wah.mp3
Blitz Krieg
joegagan
i like the sound of it!
i was also advised to keep the two caps equal value. perhaps from a pure mathematical perspective this is true, but my ears told me that i liked a mismatch there.
joegagan
here are 3, two are mine and the idiot wah that i based lefty idiot wah on. the freeper seemed to work better in front of fuzz as i recall. note the mismatch caps on the T on the lefty.
allesz
Hallo, I jump in with some questions about this circuits:
I always had luck with the idiot wah, adapted a little of course, my preference is for matched caps in the t network btw;
I don't hear much difference adding a second t network like in the colorsound.... maybe it's just that I did not try it at high volume?
I will give a go to the freeper.
joegagan
hi allesz, let us know how it goes! yes, i posted all 3 to give ideas about different ways to go.
i did pot replace on a colorsound reissue ( 90s, inductorless)  - sounded awesome!
******* youtube embed not working***
https://www.youtube.com/watch?v=REpvoPhZTGg
mac
#7
I posted a LTSpice simulation in the Spice board.
http://www.diystompboxes.com/smfforum/index.php?topic=99448.0
I'd change the 15n cap (in series with the 33k) to 22n - 33n to make the curves of the same height... that if you don't want a bump near the lows.
Useful range is about 33k - 47k or less, so rotating a 100k linear pot 90 degrees should work.
R8 is not 33k but 470 ohm.
If you make both caps equal try 4n7, 3n3. 2n2 might sound too trebly.
mac
karul
#8
Quote from: joegagan on May 28, 2014, 05:12:19 PM******* youtube embed not working***
it is working -
but for some reason only with HTTP (Hypertext Transfer Protocol) but not HTTPS (Hypertext Transfer Protocol Secure)
when you are copying link from youtube the addres is https://www.youtube.com/watch?v=....  - just change it to http://www.youtube.com/watch?v=.... and you're done
joegagan
thanks for that - i tried goofing wiht it, i am glad you figured it out. thanks for posting. now for some gratuitous wah pot porn. ( same wah as the one in video)
