Need help resurrecting an old Dynacord EC280 BBD Delay
Started by drolo, May 26, 2014, 08:44:33 AM
drolo
I have had this great delay lying around dead on my bench for a couple of years now, never finding the courage to debug it.
It was working fine when I bought it but stopped all of a sudden.
I only get dry signal and no delay anymore.
These last weeks, I decided to dive into it (and at the same time learn a bit about BBD's which I have never worked with)
This is a link to the schematic: http://www.davidrolo.com/wp-content/uploads/2014/05/EC_280_Schematic.pdf
Power Supply is working fine. All chips are powered.
I traced the signal up to the input of the first BBD (TDA1022), but no output from that BBD. I tried swapping around a few BBD's but still no output. I can't imagine that all of the BBD's suddenly died..
If I understood correctly, the MC14011 is responsible for the BBD's clock. I hooked up my MM to measure the frequency at its output but don't read anything.
My MM can measure up to 10MHz, from what I understood from the datasheet, the TDA1022 is rated for a clock from 5 – 500KHz. So my MM should be reading it.
Here is the section showing the clock:
Would a missing clock result in the BBD presenting no output?
If yes, I will try to replace the MC14011 (and perhaps the MC14027 and MC14049 as well)
There is also a CA3080 responsible for varying the clock that the MC14011 generates. I measured that its output increases when I turn up the speed button, so this should mean that it is working correctly?
Am I on the right track?
Any pointers or tips will be very welcome.
Scruffie
If the BBD has no clock, it will not work so you are right to suspect the 4011, 4027 & 4049, CMOS chips like that are static sensitive so they certainly do die and with no clock pulse being generated by them, looks like you have your answer  :)
drolo
Quote from: Scruffie on May 26, 2014, 09:03:12 AM
I ordered the chips and am patiently waiting by the mailbox :-)
