help me out with this schematic/pcb layout supreaux deux
Started by ccstudios, June 09, 2014, 06:33:44 PM
ccstudios
I'm using ROG Supreaux Deux with a max1044 to supply 18v. I basically copied his schematic and added a voltage doubler using the max1044.
heres the ROG schematic:
my drains are getting around a volt and the trimpots only change the voltage about .10V so im thinking my voltage doubler is not right.
any thoughts?
UPDATE: problem fixed. stupid solder bridge
mth5044
Since you can check the drains of the transistor's, did you check that you are getting 18V out of the voltage doubler?
