Kilobyte lofi delay schematics?
Started by gasmask, June 21, 2014, 06:52:49 PM
gasmask
I would like to build this pedal:
I also found schematic of lofi delay made by Renegardian:
Is it possible to modify Renegardian's layout?
I mean including all 4 knobs and this momentary switch.
I've never use pt2399 in my circuits..
Thanks for help
Gasmask
No you can't very easily take that and make it into the Kilobyte delay. If you want to build something similar I would start with a Rebote 2.5 http://tonepad.com/project.asp?id=51 or an Echo Base, http://www.diystompboxes.com/smfforum/index.php?topic=60662.0  if you do the "dub madness" mod to the Echo Base, explained in the pdf here http://musicpcb.com/pcbs/echo-base-delay/ it will do most of what the Kilobyte does.
gasmask
Thanks for EchoBase schem. Now I know exactly how to make a dub-madness part.
;D
Well I guess I should breadboard lofi delay by Renegardian and experiment with it.
Thank you for your help  :)
