pot value
Started by upspoon12, June 24, 2014, 11:31:26 AM
upspoon12
So here's another one for you gurus,
When deciding on pot values, is the higher the value almost equivalent to a higher resolution in a sense?
Say i put together a pedal it calls for a 5k linear. (aside from resistance) why 5k? why not 1k or 20k or 100k?
And does the same apply to log pots as well?
peterg
There are many applications for pots so your questions are difficult to answer. The attached threads will tell you everything you want to know, and then some, about pots.
http://www.geofex.com/article_folders/potsecrets/potscret.htm
http://www.beavisaudio.com/techpages/Pots/
upspoon12
awesome thanks a lot!
