How to make this Boss FA-1 louder?
Started by Jmkrull, July 07, 2014, 12:43:50 PM
Jmkrull
Hey,
I built this and notice there is a substantial volume cut with the parts listed in this layout. Is there anything I can do/change to boost the output volume up a little bit?
Replace R6 with 1M.  Stock, it is a 470k feedback resistor.  The 1meg "Volume" control is actually a gain control in parallel with R6.  At max resistance, it is 1M in parallel with 470k, or 320k.  With R5 (15k) as the input resistance, that gives the stage a max gain of 320/15=21x.  If you make R6 1M, that gives you a max gain of 33x.
Whether it can provide that gain cleanly is another matter, but if you want more loud, that ought to do the trick.
Jmkrull
I built the FA1 from the Ustomp pcb layout and It's plenty loud enough
I dont know if theres anything differant in this layout.
But it should blow the roof off the amp I've used it for direct recording too
http://ustomp.com/?p=6
Quackzed
maybee double check that r14 is 470 ohms and not 470k ohms?
Good call.  Or 47k.  I've seen some resistors where I had to look very closely to tell whether that 3rd band was light brown or dark orange.
roseblood11
That ustomp layout still has the "47µF non polar" cap. It's 0.47µF of course...
I don't rely on color codes anymore. I measure every single resistor before I solder it. Takes a lot of time, but saves a lot of time during debugging!
