How to Build a 1590 Board
Started by Rebel_88, July 15, 2014, 01:39:14 PM
Rebel_88
Hi I want to change the way i create my pedals, and i want to start with the wiring of  Jacks and 3pdt.
I want to realize a PCB that can fit in the box with the less possible number of wiring. I found on Ebay a lot of Ampli Jacks and I made a Project.
I want to share it with you because this comunity helped me several times and it is time to give you back something.
The PCB uses:
- common dimension copper clad 50x70mm;
- Amp Jack,
-Standard 3PDT or pcb ones.
This is the image of the Board fitted in a 1590B Case
And at this link http://sdvpedali.altervista.org/DIY/1590Box_Board/Documentation_%201590B.pdf you can download the Project pdf.
I Know it is not a big idea but is my first contribute to this comunity.
If you have better ways to do the same thing or suggestions, are welcome.
