this looks totally useful... and CHEAP!!
Started by pinkjimiphoton, July 21, 2014, 02:09:13 AM
Hemmel
Just bought it. Karbo's screenshots got me ! ;)
Bââââ.
armdnrdy
Or maybe someone can reprogram for GE leakage..... :icon_wink:
karbomusic
Quote from: armdnrdy on August 01, 2014, 09:31:38 AM
I know I thought the same thing!
armdnrdy
A couple more questions:
What is that thing to the right of the display?
I'm thinking about housing one of these in an ABS enclosure. If I'm interpreting what I see correctly, there are only three "test" pins, with pin #1 being duplicated for orientation, and for lead spacing. Is this correct?
karbomusic
Quote from: armdnrdy on August 01, 2014, 09:45:42 AM
Yes I think that is correct on the pins, if you note the number lettering on the PCB, I think that is an accurate depiction of pins. Here is a side view as well, that "thing to the right" is part of the LCD but recessed just enough for possible mounting:
armdnrdy
Thanks for that.
In the other images it looked like that "thing' was sticking up a bit.
So...it looks doable.
hemmel - is this wot you were really looking for? it was what I was thinking of, but not finding.
owners of - are the pads next/right to the ZIF socket for SMD testing?
" I will say no more "
karbomusic
Quote from: duck_arse on August 01, 2014, 10:18:07 AM
Possibly, good call since I thought it was for calibration but I think you may be right. Also if you note the translated instructions I posted in my first reply yesterday there may be some additional clues.
armdnrdy
I've read on other versions of this tester that these pads are for testing SMD.
Hemmel
I was looking for the small LED volt-meter and you provided Rob's link (thanks!).
karbomusic's pics got me interested just today.
Bââââ.
GibsonGM
Holy crow!!  I ordered mine on 7/22 also, and it came today!  I am pretty surprised and pleased by this thing...I've had a bunch of inductors lying around, with no (easy) way to determine their value.....this little bugger came thru.  I tested the accuracy against a known inductor, and it is very close (within a few %, it seems).   Same for resistances and cap values.
The 3 pads to the R of the test jack seem to be for SMD, yes.  You can hold a cap over the 1&3 pad and take a reading, ha ha.
I wonder if this can be used to match FETs?
Well worth $20, IMO.
karbomusic
Quote from: GibsonGM on August 01, 2014, 07:54:26 PM
YAY!
Yes I agree, so far a no-brainer at that price.
GibsonGM
I did some comparisons between this and my more expensive DMM....they agree pretty closely.  Maybe a couple nF discrepancy as was suggested, but resistance matched down to 10ths of ohms.   I like the ESR feature...
Ripdivot
Quote from: karbomusic on August 01, 2014, 09:59:42 AM
Does it test JFETs or only mosfets? I've been reading about them but can't find anything about JFET testing.
armdnrdy
#55
This is what is written in the description of the tester linked on the first page of this thread:
Automatically detect NPN, PNP bipolar transistors , N -channel and P -channel MOS FET, JFET , diodes , two diodes, thyristors small power unidirectional and bidirectional thyristor.
This is the same tester with the green LCD back lit display and the yellow PC board shown in this thread.
Maybe someone who has received this tester already can confirm JFET testing.
karbomusic
Quote from: Ripdivot on August 02, 2014, 10:50:02 AM
GibsonGM
#57
What I'd like to know is if you can match JFETs with that data.  Kind of an area I don't go that far into.....I just use the 2 voltage source + meter trick, but it takes time.
IOW, there is Vgs, but is I  the same as IDss?
Ripdivot
karbomusic
Just a follow up....
I created a layout and soldered up an overdrive I was working on last night. I can't tell you how nice it was throwing each part in this thing before soldering. I usually like to measure each part before I commit it to the perf board so that I know its a good and correct part and it also just gives me a feel for the circuit as a whole; keeps the debugging down which is the main reason.
It was beautiful to grab a part, hit one button to see the real value, solder.   8)
