Help Troubleshooting a Tonmann Paramix
Started by Freekmagnet, August 07, 2014, 01:43:16 AM
Freekmagnet
Hi,
I assembled a Guitar PCB Paramix board and mounted it in the box.
Here's the schematic:
http://www.guitarpcb.com/PDF%20Files/ParaMix%20v4.pdf
Bypass works, the effect doesn't. The LED doesn't even light up.
I was pretty careful when I populated the board. I looked at each joint through a magnifying loop, they all seemed good. The wires going into the board are secure and none of the wires seem to be crossed. I tested the stomp switch and it seems to be OK.
I pulled out the IC, and the LED lit up.
What would be my best line of troubleshooting attack from here?
Audio probe? Multimeter to trace continuity from the battery?
Any suggestions appreciated. Thanks.
Jeremy
Check out the sticky DEBUGGING thread at the top of this forum.
samhay
Looks like the IC is shorting your V+ to ground. Did you have it the right way round and can you try another?
Take voltages with AND without the IC socketed.
Freekmagnet
I will take some voltages and post them later today. Thanks.
I think I do have another IC floating around somewhere. The IC on the board is socketed and I'm pretty sure it's pointing in the right direction. I already tried flipping it around last night and there was no change.
Freekmagnet
Here's a question - should I try another IC first or wait until I take voltages? Say there's something wrong my wiring, would I risk damaging the IC?
J
Freekmagnet
Freekmagnet
Voltage from the wall wart into the board: 9v
IC 1 -
1: 4.4v
2: 4.2v
3: 4.1v
4: 9v
5: 4.1v
6: 4.4v
7: 4.4v
8: 4.4v
9: 3v
10: 1v
11: 0v
12: .75v
13: .75v
14: 8v
With the IC Removed:
1: 0v
2: 0v
3: 4.4v
4: 9v
5: 4.4v
6: 0v
7: 0v
8: .25v
9: .25v
10: .25v
11: 0v
12: .25v
13: 0v
14: 0v
mth5044
Am I missing where the build doc even says what IC1 is? Seems very sloppy, but I'm assuming you are using a TL074. Your power rails look good on pins 4 and 11. Check all the voltages where VB connects (on R13/14/2/6) and also triple check the values of R2 and 6.
Freekmagnet
Quote from: mth5044 on August 07, 2014, 03:18:29 PM
You raise a good point - I don't see anything about the IC in the documentation either. It is a TL074. I must have read it somewhere, 'cuz I'm not smart enough to make something like that up. I'll look again.
I'll take a look at those VB connects and resistor values.
Freekmagnet
Quote from: Freekmagnet on August 07, 2014, 03:25:38 PM
Here it is - TL074
http://www.guitarpcb.com/apps/forums/topics/show/8230446-paramix-by-tomann
samhay
There is something wrong with your VB supply - it looks ok at pin 3, but is getting loaded down badly elsewhere. Check resistor values and the orientation of your electrolytic capacitors.
If that all checks out, take a look at the wiring to your switch too.
Freekmagnet
OK I checked those voltages. I took two measurements - one on each side of the resistor. The first number is the side going closest to the IC.
R13: 4.4v / 9v
R14: 4.4v / 0v
R2: .25v / 4.4v
R6: 4.4v / .25v
R2 and R6 appear to be the correct values at 1M.
Freekmagnet
Quote from: samhay on August 07, 2014, 04:18:52 PM
I'll take a look at this next.
jimilee
One of the resistors was listed as a 100k, but was suppose to be a 10k. I had an issue with one also. Search the tech forum over there.
mth5044
You're getting the VB on the correct side of resistors, but a 4.15V drop across the 1M resistor seems... not right.
Freekmagnet
Well, I followed some advice I found from elsewhere. I reflowed all of the joints and even replaced a few wires. I swapped out the IC with another.
No change. The pedal is dead. Voltages on the IC are roughly the same (within an couple decimals).
I searched all over the Tonmann forum and couldn't fine any reference to a 100K vs 10K resistor.
Anyone else? Any suggestions?
Thanks,
Jeremy
any Ic, ALL IC's, only go one way, socket or solder. mark the IC you tried both ways, and put it somewhere you can't reach.
pins 8 and 9 are connected on the circuit, so they must show the same voltage at all times. with the IC removed, and power off, use your ohms/continuity range on dmm to check the resistance between each of pins 8, 9, 10 and ground. and pin 12, for both sw1 positions.
" I will say no more "
