High hfe 2n5133s???
Started by Giglawyer, August 07, 2014, 08:49:51 AM
Giglawyer
A few years ago, I ordered some 2n5133s, so that when I "had time", I would get to building a proper Ram's Head Big Muff.  Well, I have had the board populated for a while, and and am soon going to do the finish wiring and box it up.  On an off chance, I saw some other posts on 2n5133s, and saw that the hfe for these should be in the 50-100 range, but that many people were using other transistors to get a higher hfe and more gain.  On a whim, I tested the hfe on my 2n5133s (which bear the Motorola "M" and were purchased form a reputable dealer, I think).
Strangely ,the 4 tested were 334, 367, 389, and 407.
Huh?
EIther I am testing them wrong, these aren't really 2n5133s, or something else is going on.  I am excited to hear how they sound.
Any thoughts?
Check out my builds - http://www.giglawyer.com
Giglawyer
On a side note, these are in the "metal can" transistors, not the TO-92 plastic ones.
well, I  wuz gunna say check the datasheet, but they are hard to find. so, read this, instead ....
http://www.diystompboxes.com/smfforum/index.php?topic=46281.0
" I will say no more "
Giglawyer
So I could be insanely lucky?  LOL...
I should have taken a picture, but mine look like this:
And I am assuming the E-B-C layout as related to the tab on the case is the same.  Could it be different?
I really have to get this boxed up and tested now...
smallbearelec
The factory spec for the 2N5133 was Hfe 50 minimum, which means that it can be Anything above that. All the old-stock parts  I have seen are epoxy "dots",   but it was made by so many shops that I'm not surprised that you found a TO-5 can version. Many people prize the high-gain lots, so enjoy your build.
Giglawyer
Thanks.  BTW, I don't know if mine are actually a TO5 build.   This is a better image of what mine look like, except mine don't have gold leads:
Again, I assume the tab marks the emitter lead.
smallbearelec
Quote from: Giglawyer on August 07, 2014, 02:33:10 PM
That looks like TO-18, and you say it has the Motorola "M". Yea, probably good stuff. BTW: If you want to try some of the kind of parts that EH was using back-in-the-day, I have found numerous Fairchild and National "Dots" that hit gains of several hundred.
http://www.smallbearelec.com/servlet/Categories?category=Transistors%2C+Bipolar+Si+%26+Unijunction%3ATO-106%2C+TO-109+and+TO-110+%22Dots%22
Giglawyer
Giglawyer
BTW:  Just received my latest order from Small Bear in RECORD time.  Thanks for the excellent service.
CodeMonk
I've got a few NOS metal can 2N5133's
IIRC, they had hFE's of around 500.
A sheet I found (from a secondary supplier) shows:
Min 60
Typ 220
Max 1000 (all at 1mA 5V)
Typ 50 (at 50uA 10V)
Also 20V and 60MHz.
I agree that this says "more than 60" for all practical purpose. (If any significant number were really hFE near 1,000 they would sort-out and sell these at high price.)
The Gregg-observed 330-400 numbers are "better than typical" but not enough to matter in any well-behaved circuit.
Giglawyer
At this point, all 8 of the 2n5133s I have test between 300-430.  Should make for a nice Muff, I hope.
