TREMSHIFTER
Started by deadastronaut, August 16, 2014, 05:28:13 PM
ChriTracker
Can I repace the toggle switch for tone with a potentiometer?
robat
#101
Thanks dude
HI ,sure you can use a 3pdt toggle switch wired up the same way.
hang on a second, i'll draw up a quick sketch ok .
back in a bit...rob . ;)
edit: done on pm... 8)
Scribe
#103
Awesome schematic, Rob!
Would it be possible to add a 'resonance' or 'mix' control for the filter by adding a pot right before the filter on/off switch, or would that also alter the voicing of the filter?
Edit: meant to say resonance, not depth  :icon_rolleyes:
hi, the filter intensity is controlled by the LDR2.
you could add yet another switch, (which i avoided btw  ::))
to go between a pot or the LDR2.
so the new pot becomes the same as the LDR2 but with a manual option too.
cheers rob .  8)
bamslam69
Hey Rob, I'm in the process of ordering parts for a Tremshifter, off the BOM.
I have a quick noob question, regarding the LDR's, as I've never worked with them before.
Is one of these okay? Or can someone point to another one?
https://www.taydaelectronics.com/photo-conductive-cell-resistor-ldr-650nm-radial-ke-10720.html
And it's just a matter of heatshrinking the led & ldr's together, I gather by the pics?
Thanks in advance.
Still got the PCB (& a wah light plate) to order as well.
Cheers,
Pete
Yeah Nah - Nah Yeah
hi pete, yes they are the ones....
they dont specify the resistance?
anyway, yes you face the led to the ldr and heatshrink.
8)
try on ebay, 10-20k  to 1M.
bamslam69
Thanks Rob
By the power of Google, I found a data sheet for it. 10k-20k. resistance. Couldn't find one available on Smallbear.
https://www.digchip.com/datasheets/parts/datasheet/518/KE10720-pdf.php
Anything found in the stores here in Sydney are no better, and cost over $3 each. On the other hand I can grab a bunch of 20x off fleabay for $1... surely I can find a couple out of them that would do the job! haha.
Yeah Nah - Nah Yeah
yeah man, i get mine off flea bay too....cant go wrong for that price.. 8)
bamslam69
Oh, you do have Tremshifter PCBs in stock, do you?
Yeah Nah - Nah Yeah
bamslam69
Dumbass question here - What's the best/easiest way to match LDR's? Never worked with them before.
I'm in the process of googling, but if someone can beat me to it, I'd be grateful!
Yeah Nah - Nah Yeah
Salitre
Hi! I need some help or hints  :-\
I'm building this one (with an "official" pcb) and I'm having an strange problem. The thing is:
- Leds are flashing, pots working (or it seems so) and the leds for de LDR ar flashing too.
- I can't get any sound from the board, if I take out IC1 some signal is crossing, but as soon as I put again IC1 is deadly quiet. Also if I unplug the power cable I'm having again a little bit of signal.
I have double chequed continuity and some kind of shorts, haven't found anything, also tried a bunch of TL072....
¿Some sggestions? Cheers and thanks!
hows the voltages on IC1?.
pins 3/5 should have 4.5v. for bias.
make sure vol pot is up....turn speed up too....
Salitre
Thanks for the quick reply Rob ;)
4,4v on both, just a little drop but it should be ok.
Also vol and speed are on the max...
It's frustrating seeing the lights flashing so cool without sound  :icon_lol:
yeah, your gonna have to probe / trace through from pin 1 to pin 6/7 and see where the drop is...
which might be your LDR which is in series....from pin 1, via resistor to pin 6
is the value of that resistor ok?...R10?.
Salitre
Working now!
It was just a faulty set of tl072, changed and great sounding... except I changed (not in purpouse) C5 from 1u to 1n... it was honky as hell  :icon_lol:
Great sounding tremolo, really nice.
After this and Chasm Reverb working, next one will be Abductor delay II, but that's a really scary one XD
Thanks for the help!
cool glad you got it working man....
the 'dreamtime' is a les scary build... ;)
have fun. rob .
bamslam69
Glad I saw this. I'm having a similar issue as Salitre.
Basically it's still sitting dead on my test board since last september, Life got in the way.
Anyway, I've got a couple of extra IC's which I'll try eventually.
Yeah Nah - Nah Yeah
bamslam69
Finally got my tremshifter pcb functional!
Turned out to only be a dodgy soldering joint at the input.
Next is to make a purdy box for it.
Yeah Nah - Nah Yeah
