Which Switches are needed for GGG TubeScreamer Mods?
Started by Hav, September 06, 2014, 07:19:06 AM
Hav
Hi,
having a bit of a problem working out which switches I need for the mods over at General Guitar Gadgets 'Clipper' and 'AMZ Fat' mods...
just about to order batch parts want to make sure its correct...
this is where i am ordering from:
http://www.rapidonline.com/electronic-components/miniature-toggle-switches-sci-30254
well, the fat mod is just shorting a cap, no? so any single pole, single or double throw will do (spst or spdt).
as for the clipping diodes switch, with a spdt-centre-off switch, you get the centre position connecting nothing. in this position, your highest Vf diodes do the clipping. in the 2 outer positions, you can connect lower Vf diodes, or short across one of series diodes.
any of that make sense? how many clipp options are you thinking of?
" I will say no more "
Hav
thanks for the reply! :-)
yes it kind of makes sense. so for the fat mod its just a On-off switch, thats fine and makes sense..
the clipping switch, is an on-off-on switch?
whats confusing me is the way they are written = 'on-off-(on)' i just want to make sure that the bracket means its momentary which really means its NOT what im looking for. I need an 'On-off-on' switch right?
Im planning of just having the 2 diodes to switch between, which should give me 3 different variations if im not mistaken..
nate77
Yep, that's correct. A basic spst on-off-on for the diode switch and an on-off for the fat switch. Pretty strait forward. Those 2 mods are very common in OD/distortion circuits. Mods on kits from places like GGG and some of the other well reputed kit suppliers are how I cut my teeth in this "hobby". Good luck my man. Luckily, this is a very straight forward set of mods.
mmmm, I've confused myself again.
I was thinking you had the north/south led combo as default, and then switched other diode combos across them. if you just want [one north/one-two south] type without the leds, you only need another spst, to short your second diode.
an complete circuit diagram including suggested mods saves lots of confusions.
