Viva Analog tube emulation
Started by PBE6, September 15, 2014, 02:59:38 PM
Quote from: samhay on September 18, 2014, 12:35:29 PM
Where I am struggling is that I don't quite understand what is happening when the output gets near the positive rail (I not proportional to v anymore), as it seems to cause the source voltage to drop.
If you're talking about the 2 opamp version then don't forget the LM358 isn't rail to rail, the output will only go up to about 1 Volt below the positive supply, I don't know if that explains anything.
PBE6
Thanks slacker, the 1V bias may do the trick for me.
Out of curiosity how close to the rail does the LM358 go? I didn't see it on the data sheet unless I'm reading it wrong/looking for the wrong parameter.
EDIT: Oops, it does say in the plain-language description that the LM358 can swing to ground when using a single supply. I guess that's why it's a good choice in the original circuit.
PBE6
Turns out I had some LM358P's lurking in the bottom of my opamp bin..mwahahah!! Ok time to breadboard..
samhay
Quote from: PBE6 on September 18, 2014, 09:05:41 PM
That's why the 358 was suggested - they tend to show up in the dusty corners of your parts bin.
samhay
Quote from: slacker on September 18, 2014, 03:26:01 PM
No, I think I am just trying too hard to understand the freak-out behaviour of the op-amp when the output hits the rails.
So here is the real quesiton. What's the best way to trim the two op-amp? I guess I am trying to understand theoretically where to set the top op-amp relative to the source voltage, which dictates how much higher the FET drain voltage is relative to source.
