Headphone amp balance
Started by juan_felt, October 02, 2014, 04:10:13 PM
juan_felt
Hi! I built this headphone amp: http://www.redcircuits.com/Page119.htm and I'm very satisfied with it. I want to add a sort of balance control that will allow Me to blend how much amount of right and left channel I hear in mono. I tried adding a pot before the volume pot, where lugs 1 and 3 are the left and right inputs, and the 2 one is the output. The problem is that when I use it in the center position the volume is lower than the one in the extremes.
If anyone knows what to do or how to fix it I will really appreciate it. Thanks!
mth5044
Instead of a dual gang pot, you could use two individual pots and set each level to how you want. Alternatively you could leave the dual gang pot and replace R4 and 6 with potentiometers to alter the gain of both opamp stages. How are you summing the two circuits to make it mono as the schematic is in stereo?
juan_felt
Quote from: mth5044 on October 02, 2014, 04:15:53 PM
Hi! Thanks for your reply. The circuit stays in stereo, my idea is to "blend" both input signals into two of the same and then feed them to the amplifier. I thought about the two volumes, but I'd like to keep one volume and try to add the balance pot (if possible).
GGBB
Replace R4 and R6 with a 100k balance pot.  Replace R2 and R3 with 100k.  Replace C3 and C7 with 15pF.
