Stratoblaster hickup
Started by Bison204, October 21, 2014, 01:43:34 AM
Bison204
Hi everyone, first time poster. Been lurking a while, built 2 pedals and am having a little issue with the stratoblaster. It works and gives lots of boost but gives no boost at all until the knob is turned to about 2 o clock. Then it's full boost. It's kind of all or nothing with the cut off being around 2 o clock any ideas where I might have gone wrong?
nocentelli
That sounds normal due to the way the gain control works. A simple fix is to use a 20k or even 10k pot instead.
GibsonGM
Hi Bison, welcome to the forum!   Here is the schematic so people can see what you mean (useful to post it):  http://www.beavisaudio.com/schematics/Alembic-Stratoblaster-Schematic.htm
Yeah, looks like nocentelli hit on it...that gain pot would be more useful if it were a smaller value.   Don't forget it's a LINEAR or "B" taper pot, not audio taper, if you go buying/ordering...This is just because the useful range of the pot is bunched up, and the higher resistance it can provide does nothing in the circuit (for lack of an easier way to explain that, ha ha).
Bison204
Thanks to both of you for the knowledgeable replies! I will try a different pot in it asap. Can't wait to get this thing going!   :icon_cool:
GibsonGM
Good luck!  You'll get this one going, then probably want to build 10 more pedals, ha ha!   :)
Elijah-Baley
It has been like that for me!  ;D
Some circuits complete, but just one in a box.
GibsonGM
Quote from: Elijah-Baley on October 22, 2014, 08:04:00 AM
Thought I was the only one, ha ha...I have 4 on breadboard right now, trying to get "perfect".   Others are on perf, pots and jacks hanging off.    but I DO have 10+ distortions, vibes/phaser things that I use in my board - managed to get them done and out the door before the REAL sickness hit...
