Audio probe questions
Started by Adamo, October 21, 2014, 08:32:32 PM
Adamo
I'm having a blast debugging a couple of pedals (one old, one new build) with an audio probe. I have a couple of questions: is it normal when using a probe and touching one leg of a resistor that you get a loud, clear sound passing but on the other leg it is much quieter?
Also, when probing a transistor, it seems like I get 'sound' when touching the base but not on the collector or the emitter. Is this expected?
armdnrdy
Is this the A8 that you're audio probing?
Adamo
No, not yet. Coincidentally, I just finished a GGG FoxxTone that's not working either so I'm starting with that one. I'm pretty new at this stuff and I suspect I have some cold solder joints. I'm going to debug the A8 next. The audio probe is a pretty neat little tool.
Adamo
I'll simplify my question--------when testing components with an audio probe in a 'working' pedal, should I get 'sound' on all legs of all components on the board? And...should the sound be of the same volume?
armdnrdy
No and No.
Post a schematic or a link to what your debugging..and we'll clue you into where you should probe to find the signal.
Adamo
Here's the schematic for the Ampeg A8 analog delay . Supposedly this Guyatone is the same schematic:
https://dl.dropboxusercontent.com/u/53299166/DIYstompboxes/Guyatone%20-%20PS-006%20-%20schematic.jpg
The pedal is giving me a clean signal when the pedal is engaged or not. No delay whatsoever. I wiggled and checked all components. Led seems to work properly.
GibsonGM
The volume drop after a resistor is normal.   If you touch power, you should get a *click*, too.  You are using a cap in series with your probe, right?  Just asking....it blocks DC and allows only what we're interested in, the audio, to come thru.
At a working transistor, I'd expect signal at the base, and also at the collector (or emitter if it is wired with E as output, Q2 on the Guyatone), maybe a very low signal at E anyway.    I think NO signal on the collector = a problem in that area.
Why don't you draw in with red the signal path you are probing, mark it as you go?  The re-up the pic where it stops, and you should be quite close to where your troubles are!  :)
Adamo
I'm actually get some great help on this issue right here:
http://www.diystompboxes.com/smfforum/index.php?topic=108906.0
I feel bad having 2 threads going for one issue.
GibsonGM
Oh, that's no good, busted!!  LOL.   J/K
Cool, you'll get it sorted out over there, looks like you're well on your way.
