Rack mount DIY 'stuff'
Started by scratch, October 28, 2014, 07:55:21 PM
scratch
Thought I'd start a thread for rack mounted DIY things ...
Power supply unit I rebuilt. Started off as a single +/- 15V, then I wanted to add +/- 12V output ... the voltages from fixed regulators were never quite right on. Also output was sagging under load (single 2A output transformer). So I rebuilt the using adjustable regulators, and seperate 3.57A output transformers for each +/- voltage.
Originaly had only two LED's, added another p0air for the other output, but alginment slighty off.
Using three pin Mate-n-Lock connectors for output (had a bunch of pre made cables from my field service days), oh yeah also a pair of AC outlets (switched)
Inside layout, circuit built on Radio Shack protoboards
more to come ... lots of things half way done.
Denis,
Nothing witty yet ...
scratch
I'm realising I didn't describe the 'chassis' ...
It is a Hammond 1434-32 (17" W x 10" D x 3" H) bolted onto a blank Hammond (unfinished 2U - 3.5" high) aluminum rack mount panel via a pair of Hammond M268-1 handles (had these forever, no longer available)
Denis,
scratch
Here is Thomas Henry designed Voltage Controlled Analog Delay... Not working yet. Need to build Armnrdy's BBD tester to test my SAD4096.
Built the chassis from scratch, using a blank Hammond Grey 1U panel for starters.
Front View
http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=51769&g2_serialNumber=1
Inside side view
http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=51766&g2_serialNumber=1
Rear view
Denis,
scratch
my Craig Anderton inspired mixer, 6 channel input, added a three band tone control with bypass, FX loop and In-phase, Out-phse and XLR outputs to cover all the bases.
Par-Metal enclosure which I picked up somewhere in Toronto.
Front panel;
http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=51783&g2_serialNumber=2
Gut shot (still lots of room if I ever re-work these)
http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=51786&g2_serialNumber=2
Rear panel;
http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=51789&g2_serialNumber=2
Denis,
scratch
manged to to embbed the pictures correctly the first time, but can't seem to get it right anymore ... maybe next time.
Denis,
glops
Scratch, great stuff. I've been wanting to build some rack mount units for myself, no one seems to do it much.
scratch
Thanks Glops! I think on the whole rack mount enclosures are more expensive than stompbox ones. So I'm on the lookout to find ways to roll your own cheaper.
Denis,
Quote from: scratch on October 28, 2014, 07:55:21 PM
Quote from: scratch on November 13, 2014, 06:27:56 PM
Front View
Inside side view
Rear view
Quote from: scratch on November 21, 2014, 06:48:07 PM
Front panel;
Rear panel;
Great looking builds Scratch! Nice to see room to breath, get claustrophobic looking at all the 1590A's.
scratch
Thanks Dave! Indeed, I like some room to layout 'stuff' inside an enclosure. I have an Anderton Phase Shifter with envellope follower in the a chassis the same as the mixer. I'll be posting picture of it next.
I'm working on a couple of smaller (Bud) enclosures for a couple of things right now and I'm trying a half reack setup for another couple of things.
Not enuf hours in the day ...
Denis,
With multiple effects in one enclosure, you have room to allow a switched input/output bus structure.  The input and each output goes to a line that can be selected by any effect input using a rotary switch and you can get one input jack and one output jack and have the effects connected in any order or disconnected entirely.
scratch
Amptramp, something I might consider down the road ... my current set of projects uses most of the front panel, not leaving room for switching
Denis,
Just a modded CE2
Link
https://imageshack.com/i/pbmSOq8ej
scratch
I like it!!! What did you use for the rack mount enclosure?
Denis,
Laser cut 2mm steel custom made by my bruv in law.
Rich
Ice-9
Quote from: Kipper4 on January 11, 2015, 09:01:49 AM
Rich
Rich does can your bruv in law make stuff like this to buy. I would love some custom enclosures to my spec. Same enclosures for a floor unit about 10 off and in the UK.
I'll pm the company tel number and you can ask them mate. I can't see why it wouldn't happen
Ice-9
scratch
not sure how this is going to show up as ... link to Snapfish 'album' ...
This is my Craig Anderton EPFM Phase Shifter w/ Eveloppe Follower ...
http://www2.snapfish.com/snapfish/thumbnailshare/AlbumID=16206355013/a=124177081_124177081/otsc=SHR/otsi=SALBlink/COBRAND_NAME=snapfish/
Denis,
scratch
oik,that\s not working as expected. need to find another place to host the images.
Denis,
Try imgur.com.  Dead simple.  No need for an account.
