Albert Kreuzer JFET pre EQ question
Started by Eddododo, November 28, 2014, 08:35:31 PM
Eddododo
http://www.albertkreuzer.com/pics/el/pre/schem/preamp_sch21.gif
for the EQ- seems to be baxandall with a second '1 knob baxandall' as a mid control...
for his frequency/cap switching scheme... If I made the caps individually switchable, instead of 'dual-ganged', could I use it a sort-of 'Q' switching, as well as the frequency implications?
I do get the idea that  the range of the 'Q' will get outrageous quickly, but will it cause other problems ?
The Q will always be less than 1.
So you will go from "mild" to "too mild".
Breadboard it and listen.
bool
Real world advice: If you plan to mod the EQ, study the various onboard bass preamps and mirror the values/frequencies that work OK enough for you.
