Chicken Head Knob unscrewable
Started by Elijah-Baley, February 09, 2015, 08:29:47 AM
Elijah-Baley
Hello.
I bought from Tayda, in two different orders, 2 white Chicken Head knobs and 1 red Chicken Head knob.
But the screws doesn't have the drive! I looked inside with a light. My screwdiver turns with no effect.
There's something wrong with me or my knobs are weird?
How I can set these knobs?!  :icon_confused:
is the problem *no grub/set screw, *no thread on grub screw, *no brass insert for grub, *no thread for grub in insert, *wrong screwdriver tip, *product sourced from tadya ?
can we see photo of what you have?
" I will say no more "
GibsonGM
+1   A lot of the time, the screwdriver tip is either too fat for the slot in the screw, or it tapers too broadly to really go in the hole, so you're spinning ABOVE the screw, not really touching it....if so, you file the screwdriver edges a little to make it narrower.
Elijah-Baley
#3
Tried to make a picture, but is complicated see deep enough, anyway I don't see the drive on the screw, really seems there's no. My screwdriver works with others knobs.
This is the knob: http://www.taydaelectronics.com/hardware/chickenhead-red-knob.html
weasle76
Hi.
If they are the same as the ones I got from Tayda, you might want to try a 1.5mm hex key.
Hope this helps!
For full list of my shi... I mean stuff, please visit my BandMix page. http://www.bandmix.co.uk/waynep76/
Elijah-Baley
Elijah-Baley
Quote from: weasle76 on February 09, 2015, 09:18:20 AM
Hi.
Hope this helps!
C'mon!  :o
Brisance
seems like a flat/phillips peg, hexagonal hole problem
Quote from: Brisance on February 09, 2015, 09:30:06 AM
took the words right out from under my fingers.
next question, why are tayda selling hex head set screw knobs?
weasle76
It caught me out a few times to start with! Not sure what the deal is, the other set screws have been slotted for a flat blade screwdriver.
It's just been on the chicken heads in my experience.
Elijah-Baley
Everybody right, anyway. It is exactly an hex screw.
Anyway, I don't have an hex key, probably my cousin lost when I had borrow him my bad "statocaster" style guitar.
But... I done!  8)
Using this:
I don't know what is it. I have at home this thing from some weeks, maybe my father found it outside. Seems to me a glasses of a doll or a teddy bear. Whatever. I disassembled it and use to screw. That is not "hexed", but round, and with some difficulties it had worked.  ;D
I finished my Bazz Fuss 2-clipping mode.  ;)
Thank you guys!
Have fun as I do!  :P
Bishop Vogue
+1.  I've had the same issue with the same Tayda product, but use a hex key and it works perfectly.
Elijah-Baley
Yep, I need that key.  :-\
I'm going to buy a mex stratocaster and I should use a hex key for set the bridge.
the arm on ^ those glasses; I'm glad I'm not wearing ones like that.
looks like you coulda filed a shape on the bent end of that glasses arm, use it as an allen.
GGBB
EMG knobs use hex drive set screws.
