Dean Markley Overlord 3 switch doesn't bypass - cuts sound off completely
Started by pete_g, February 26, 2015, 05:31:35 AM
pete_g
Forgive me if it's been addressed somewhere before but I'd like to to know what the most common solution to this problem is as a mate had the same problem with his one a few years back as well.
Can someone point me to where this problem has been resolved so i can attempt to fix it?
I know you can't just change the switch as it has something to do with FET's being the issue.
Please help, I'm not an expert but have built a few overdrives, fuzzes and distortions in the past
JerS
Read post #9 in this other forum: http://music-electronics-forum.com/t1553/ - Mark Hammer explains how to true bypass this thing. The schematic is also posted there.
pete_g
mine is the non valve, transistor version with just the vol tone and drive. that post is for a different schematic.
pete_g
pete_g
no-one encountered this problem on the overlord III then?
The above link is for the 5 knob overlord 1 not the 3 knob one I have.
pete_g
JerS
Pete,
I imagine that even though you have the solid state Overlord, the schematic for the tube version is probably the same as far as the switching circuit goes. If you could take a look at your pedal and poke around with a multimeter to see if that part of the circuit is the same, you may be able to diagnose what is going on and why your pedal doesn't pass sound.
It might also be worthwhile to audio probe that sucker to see if it is even a switching issue at all.
pete_g
According to the linked schematic the output lug 2 goes to a 1 k resistor and then to a RSK30A transistor but mine goes straight to a tC4066BP IC.
I don't think I'll be able too work it out here. Even the other guy with the correct schem had problems when he removed transistors.
