Sandpaper deals
Started by Beo, March 10, 2015, 02:32:37 AM
Beo
Enclosure sanding can be an expensive activity. A very non-flat or pitted cast requires a lot of elbow grease to prep for etching, and it's easy to go through a few sheets of sandpaper. A quick Amazon search shows good wet/dry paper going for 8$ or more for a 5 sheet pack. Seems strange to spend as much on sandpaper as on the enclosure itself.
So, anyone have any good local or online sources for sandpaper?
LightSoundGeometry
no wonder my paint aint sticking ..I need to sand the Al more before I even spray etching primer. its expensive but I guess worth it. wally mart should have the best deals?
Elijah-Baley
I am not sure if this could help you, but in tese days I'm getting some information to polish the aluminium enclosures.
I started to scratch with some sandpaper. Somebody use start with 240 grit sandpaper, but I tried directly with a 600 then 1000. I have to buy a 0000 super fine steel wool and try whit that. Last step: a polish car product for erase the scratch, I don't know how it calls in english.
I still have to try.
^ rubbing compound, or T-cut.
i have a local small family run hardware shop...very rare these days,
but they are great, you can buy each grade by the sheet....try and find a small shop
you may have better value, and choice,,
Elijah-Baley
Brisance
Something like this?
Sorry, couldn't resist...
