An idea for etching circuit boards and enclosures.
Started by NakedApe, March 13, 2015, 03:47:55 AM
NakedApe
I've always struggled with ironing toner onto my circuit boards to etch them, it just seems that no matter how hard I try there is always going to be a bit of smudging, harming ther resolution.  Now that I want to try etching an enclosure, It would be nice to have a way of doing it without ironing toner on.
I know there are boards for sale that are coated with a photosensitive layer that can be developed after being exposed through an acetate positive.  I also know that t-shirt silk screening uses a kind of photosensitive emulsion to prepare their screens, and they can get a great amount of detail with this method.
My idea is to try coating the board or enclosure with the emulsion, then exposing a design directly on the board or enclosure.  The result would be a positive stencil that will hopefully be resistant to the ferric chloride, since it seems to be some kind of plastic.
I'm going searching for a place to buy the emulsion, and hopefully I will report back with some tests as soon as I can.
In yhe meantime, has anyone tried this? If so, is there a good reason why not to do it?
Happy etching.
What are you, some kind of wizard?
years ago, this process used to be called "Riston". a full range of chemicals, pre-coated boards and acetate sheets were available, and you could expose to the sun or a uv tube/bulb. keep searching.
" I will say no more "
Beo
I think getting the enclosure truly sanded flat is the main challenge. Ironing works much better and consistent then. It takes a lot of elbow grease and can eat up sandpaper to get a box truly flat. Has anyone priced local metalshops to see how much it would cost to have them sand/grind flat tops onto enclosures? I'm thinking if you went in with a batch of 10 or 20 enclosures, it might not be too expensive.
~arph
Erm, you have electrical sanders.. I use one all the time for enclosure sanding, not much elbow grease needed  :icon_razz:
NakedApe
I can usually get a mirror finish on the metal before I iron, and even then it gives me problems... in any case, I just picked up some photo emulsion from a local silk screening shop and I´m going to star experimenting tonight with some pcbs and a piece of aluminum I have lying around. Ill post some results when i have some
Tony Forestiere
#5
I had not heard of this method, so I did a bit of research.
Are you planning on using a modification of this method? Looks feasible for our purposes. Good luck, and let us know how it goes.
*edit* darned "s"  >:( I do miss the preview option.
NakedApe
Quote from: Tony Forestiere on March 13, 2015, 07:11:14 PM
Yes, except I have coated the emulsion directly onto a piece of copper clad board and a couple of pieces of aluminum, I´m going to try burning the designs into them as soon as they are dry!
NakedApe
So far, my results show that this is not going to work. As soon as I put the developed piece into the etchant it just dissolved away.   Oh well, i guess I´ll have to make some shirts or something.
Tony Forestiere
Bummer. :( I thought there was potential to that idea. Thanks for the update and taking the leap.
