Can this thingy be done?
Started by JebemMajke, March 15, 2015, 09:03:44 PM
JebemMajke
I've decided to make this kind of eq, because of simplicity, and because it has 2 eqs, which i think is very useful.
But i was wondering if i could add a third output, with a blend pot, like this
Or maybe a dual gang blend pot?
Because i feel like this add on would make this thing shine even more.
Edit
i was so tired last night, that i've used wrong links
JebemMajke
Just to bring it up to the beginning of the page.
Derringer
what's the output impedance on something like that?
Try a simple blend pot and if it sounds so-so compared to the signals on their own., buffer the outputs of the two signals and use a low value blend pot like 10K - 25K.
Would you be running two different signals, like two separate guitars, at once here? Or are you making like a parallel signal type blend? In which case you may then need to consider one signal going out of phase from the other.
JebemMajke
Two signals of a same bass/guitar.
R12, R13 would be around 20k
How to avoid that phase issue?
Derringer
check out RunOffGroove's "Splitter-Blend "
http://www.runoffgroove.com/splitter-blend.html
it'll buffer, blend and allow you to flip the phase of one side
