LTspice mosfet simulation, what am I doing wrong?
Started by acehobojoe, March 18, 2015, 11:27:17 AM
acehobojoe
I am attempting to model the circuit shown here with a mosfet. The specific one I am using is a BS170, I found a 2n7002 in the list of actual transistors ltspice has, which should be the same.
I'm only getting about 1db of gain or less, and I know that when I use this in a mosfet gain stage, much like the "super hard on", AMZ mosfet booster, or the  peppermill drive.
I have tested it, and it seems like the actual gain I have on my circuits is 10db or more.
here is the pic. Any help is appreciated.
Also .... I think it went from -6 to + 6 db, so that's the correct amount I think.. anyone see any problems with it though?
http://i.imgur.com/TvsQLHB.png
samhay
anotherjim
Is the DC bias on the output near 4.5v in the sim? If it's offset either way, the input signal x gain could be clipping which might well give a lower gain. The bias in the sim could well be different from a real circuit. Try a lower test signal, 0.2 to 0.3v nearer to real guitar
Have played with this kind of thing myself. I found the best biasing method to get the output to half supply volts was with a voltage divider feeding the gate via 1Meg. 33k top and 100k bottom resistors in the divider gave close to 4.5v DC level on the drain. YMMV of course.
Your plot shows 6.8dB gain.
Agree that DC voltages are a MUST.
The Source resistor R4 may be reduced (without limit) to increase gain (but it will never be monster gain).
Do not believe SPICE's .AC analysis, do a .TRAN (run a sine wave in and see what wave comes out).
mth5044
I wish I could help - I ask myself that same question every time I open up the program  :icon_lol:
acehobojoe
bool
.STEP param x No-from No-to No-stepsize
fe.:
.STEP param Re 100 1k 100
and change your emitter resistor value to {Re}
... you'll get the hang of it eventually
mac
You can add a basic guitar circuit at the input:
a series inductance of about 2H - 3H and coil resistance around 5k - 7k,
a 250k to gnd, the volume pot,
and a 220p - 330p capacitor to gnd to simulate cable capacitance.
See the spice forum for examples. Gus simple model works great.
mac
mth5044
^+10000, take a look at Gus's schematics for lots of tips.
acehobojoe
tca
