Diptrace Library Help
Started by rthryhorysak, March 20, 2015, 06:10:46 PM
rthryhorysak
I have been playing around with diptrace lately and it has been really great. My only problem is I can't figure out the component editor because I wanted to widen the holes for the transistors and add a pattern for pots. Does anyone know of a library with these things thanks! Also what resistor and cap size do you guy use? Thanks
J0K3RX
Quote from: rthryhorysak on March 20, 2015, 06:10:46 PM
Resistor and cap size for what?
For me component size is somewhat dependent on what I am making...
Have you tried the madbean lib yet?
FYI - The diptrace forum is a really good place for answers to new user questions.. Good chances are that somebody has already asked just about any question/s that you will have and you won't have to do anything but use search. Not that somebody here can't or won't answer your questions but your chances of getting a quick and precise answer are a lot better since the entire Diptrace forum is geared solely around Diptrace where as this forum is not.
rthryhorysak
QuoteResistor and cap size for what?
1/4 watt resistors and standard box films
QuoteHave you tried the madbean lib yet?
I have been looking through madbean and have yet to find a downloadable library. If you know where I could find it a link would be appreciated  :)
I will check out the diptrace forum, thanks
rthryhorysak
Alright found the library and converted it and it is just what I needed. Thank you!
J0K3RX
ha, I just sent you a link... probably the one you already found?
