Angled amp stand! Move to pictures thread please
Started by blackieNYC, March 22, 2015, 10:53:32 AM
blackieNYC
https://www.dropbox.com/s/rq8gyl6flt5ojtw/2015-01-23%2019.37.20.jpg?dl=0
Angled, or mangled. I recommend a little patience and a jigsaw, but the sawzall is very very fast.  Mind that you select an angle that will have the weight fairly centered, and - that the back edge of the stand lines up as to not poke inside and hit the tubes or wiring. Not difficult to accomplish.  If you mess up, you'll have to go out and get another.
Messing around and getting confused trying to put the image straight in from Dropbox on my phone. I intended to out this in pictures. What's a good public photo storage that will not ask the viewer to set up an account?  What are folks using to put images in posts? Imgur work?
Are we taking up a collection for Aron to expand the gallery size?  Let's do.
Nice idea.  Try imgur.com for your pictures: no account needed.
blackieNYC
Thank you.  I did see this somewhere, not my idea.
I never liked an amp blasting into my ankles, but but this pedal work, I find it best to look square into the speaker.  From 8-12 feet.  I missed a subtle problem once - it wasn't noticeable when listening off-axis.
Imgur then.
