scematic for a VERRY simple wah wah anyone?????
Started by punkbass, April 07, 2015, 01:19:44 PM
punkbass
I am building a bass and i am planning to make a wah wah inside it with a tremolo style arm instead of a pedal because there is a 3x3 inch cavity inside the body. Anyone have any suggestions?
By the way, i want to use a opamp for this purpose.
Brisance
Sorry, but... coming from a different, not tainted by guitar slang past, please stop calling the whammy bar tremolo, when it actually does vibrato...
smallbearelec
Quote from: aron on April 07, 2015, 01:50:31 PM
http://www.geofex.com/article_folders/wahpedl/wahped.htm#opampvers
For a version of that schem that has been breadboarded and includes component values known to work, please see this article:
http://diy.smallbearelec.com/Projects/ISeeWah/ISeeWah.html
But it's Not what I would call a Very simple build. Might be too many parts to fit in your cavity. Also, you don't indicate what your experience level is with FX. If you can build a bass, sure, you are handy enough to build a board layout that someone else has done. But are you up to creating on your own something buildable? As for simplicity, a Twin-T Wah (mentioned elsewhere in R. G.'s article) might be the ticket. You might even want to control it with a pressure-sensitive resistor:
http://smallbear-electronics.mybigcommerce.com/alpha-membrane-force-sensor-mf-01/
Again, however, you'd need to be able to do considerable breadboarding and layout to get to where you want to go.
joegagan
here is a  twin T that i modded from tim escobedo's ' idiot wah' i know it isn't opamp, but is very low parts count. i used a 22k pot, i think 10k might work ok as well.
the reason i bring up 10k is-- the millions of rockband video game guitar controllers had a wang bar attached with a return spring and ( usually) a 10k pot inside. they are extremely plentiful in thrift stores, i believe could be adapted for real guitar quite easily.
joegagan
mac
sajy_ho
Life is too short for being regretful about it.
Search "LOWAHT"  by earthscum tiny one tranny wah...nifty.  8)
or morley classic wah...very simple opamp wah...tweak caps for bass...
punkbass
hey, thanks everyone. i think i'm going to use the Lefty Idiot Wah, because those parts are also already available at where i'm going to make it.
can't wait to get started, i wil use a 2.5x2.5 inch velleman testboard, since i've used that type of board before for some distortions i build.
One question left: Should i make the caps bigger because it's a bass??
antonis
If you refer to In and OUT caps, yes  - but I think (not calculate) their current values are quite OK for bass..
