PEE EIGHT Octave Fuzz (only 4 parts) (SOUNDSAMPLES ADDED!)
Started by FUZZZZzzzz, April 13, 2015, 05:42:47 AM
FUZZZZzzzz
Thanks, Gary! :) The thing modulator is pretty cool indeed. I build a double thingmodulator once.. too bad it's a bit noisy.
Quote from: garcho on April 17, 2015, 06:33:34 PM
Bravo! Looking forward to messing with this.
If you haven't, check out Escobedo's/Christian's 'Thing Mod'.
"If I could make noise with anything, I was going to"
Bishop Vogue
#41
Just built this today.  I added a little mod of my own - a 100k linear pot between pin 5 and 8.  Lets you control the amount of fizz and bittcrushy-ness, although the control knob is not especially dramatic, it does make enough of a difference to be worthwhile if you are looking for a way to shape the tone.  For those who are messing with this circuit (thanks for dreaming this up, Fuzzzzzzzz) have you had any luck improving the sustain - since notes fart out very quickly?  Also curious to know if anyone has actually fried their chip with the 9v.  Maybe worth it to put a small resistor between the battery and the circuit?
stonerbox
Quote from: FUZZZZzzzz on April 19, 2015, 11:09:17 AM
Thanks for the thumbs up!  ;D  Looking from the music in you signature..you definitely have to build one yourself as well ;)
I will.  ;)
There is nothing more to be said or to be done tonight, so hand me over my violin and let us try to forget for half an hour the miserable weather and the still more miserable ways of our fellowmen. - Holmes
FUZZZZzzzz
Hi guys! thanks for verifying. and thanks for the mod!!.. worth a try. :) Im on holiday in China the coming 3 weeks.. so will only check now and then and will not be able to try anything. will read again now and then. also, try changing cap to 47f (less fizzle)
ow.. i'v burned a few 567 with a 9 v adapter.. so yes we need a voltage regulator.. see the info on the previous page ;) and lets see those photos!!!
FUZZZZzzzz
try putting a booster in front for more sustain. I used a lpb1 1 pedal in front.. also gives you a warmer sounding fuzzy result. I like this one with the notes fading quickly.. more NES sounding ;)
Quote from: Bishop Vogue on April 25, 2015, 02:47:40 PM
LightSoundGeometry
hello - and thanks for the easy layout!
is that a shared hole 9V and C1 ground?
thanks
Steben
Perhaps just a buffer in front could achieve sustain?
AFAIK the circuit has low input impedance.
sick octave synthy stuff..nice one fuzzzzzzz...
have you tried a dirt in front/behind it?...could be cool.. :icon_cool:
anotherjim
Nice. Actually more musical than I expected, and sometimes makes better bell tones than more complex circuits can manage.
If you must add something to drop the supply volts - if it takes less than 10mA, you could just use a standard LED in series and it also gives you a power indicator?
PBE6
I just built a circuit around this chip, and I'm getting a fuzzy sound but nothing like the great sounds in the demos. More like clean guitar with some fizz in the background. A few questions:
1. I'm using an LM567. Which pin is supposed to be the output? From the layout it appears that pin 8 is the output, but I got virtually no sound from that so I switched it to pin 2 as per the Thing Modulator and the Beavis Audio versions.
2. I used a 78L05 regulator to power the chip, and it's connected directly to pin 4. Is a series resistor required? Should the chip be powered closer to 9V to get the right sound?
3. I sandwiched the chip between a TL072 non-inv gain stage (pre) and an MPF102 buffer (post) because I wanted some pre-boost and I wasn't sure what the output impedance of the LM567 was. Is the chip expected to be loaded down by the guitar? I figured not since some people have mentioned using a booster on the front end, but maybe it is?
FUZZZZzzzz
What do you mean? Im a bit lost 😁
Quote from: LightSoundGeometry on May 03, 2015, 09:57:25 AM
thanks
LightSoundGeometry
#51
Quote from: FUZZZZzzzz on May 07, 2015, 05:58:56 AM
thanks
sorry bout that, does the 9v input share a hole with C2 on row E ?
i guess I can just add a row oon each end lol
FUZZZZzzzz
Breadboarding this kind of easy lay-outs Will save you kots of trouble.
1. There must be something wrong with your build. Output in this build is 8. Other designs might use other pins. It has been verified like this.
2. I have not checked this myself. Please check some voltage divider ideas on page1 and 2 of this thread
3. I think a schematic would be nice to see what you mean.
Quote from: PBE6 on May 06, 2015, 04:02:08 PM
FUZZZZzzzz
Yes!  ;)
Quote from: LightSoundGeometry on May 07, 2015, 06:04:30 AM
thanks
LightSoundGeometry
cool cool ..I am waiting on the chip in the mail lol ..its killing me , I am an octave bit crush fan !
FUZZZZzzzz
Me too... It's is a niche market but as long as we stick together we'll be fine 😉
B
Quote from: LightSoundGeometry on May 07, 2015, 06:13:14 AM
:icon_evil:
FUZZZZzzzz
what is this crap?
https://reverb.com/item/761689-pee-eight-bit-crusher-mini-1590g
he even used my sound samples..
Should I be flattered.. because it doesnt feel that way.
'its part bit crusher & part fuzz ..its unique and in a mini 1590g so I had to leave out the bypass switch. you will have to loop it or just have fun with it.'
no it isnt.. yes its unique, because its mine..
I know this shit happens when you post your ideas on a diy forum, but still would be nice if this person thanked me for it, before selling it under his own brand.
anotherjim
Sheesh! That listing is bizarre. Is it even real? And what about the description? "Doesn't work, sound like crap" and Make:"Junk"? Has the listing been hacked?
FUZZZZzzzz
#58
the guy just changed his advertisement after reading this  :-\ reverb.com is a genuine website, but apparantly he could not delete his ad after a sales and just changed it.
it looked very different a couple of hours ago.. He just changed it to avoid confrontation. But why? a simple post in this thread would have been enough. I dont mind people building stuff, but he could at least posted his build and experiences and asked if it was ok to sell a build he was probably not using himself anymore
people like this just take the fun out of posting here
your not alone fuzzz...
had the exact same thing a while back....even used my vid to demo it :icon_rolleyes:
it certainly doesn't feel 'flattering' at all ...that's the wonderful web eh.. :-\
