AB Box. Two guitars to one amp
Started by Buffalo Tom, April 15, 2015, 12:27:44 PM
Buffalo Tom
Hi. Can I use this circuit without modify and use it the other way around.
Two inputs to one output?  :o
http://www.fulltone.com/sites/default/files/manuals/fultone-a-b-switcher.pdf
Are you referring to plugging in two guitars then using them one at a time, using the box to mute the one not being used? Because in that case it would work.
Buffalo Tom
#2
Quote from: vigilante397 on April 15, 2015, 02:23:26 PM
Yes exactly. I wanna switch between two inputs (guitars) to one output (amp).   :icon_cool:
