Small Time delay - Oscillation switch?
Started by Chugs, April 16, 2015, 03:59:42 AM
Chugs
I built Merlin's Small Time delay a couple of years and really like it. I was thinking of adding a second foot switch that would send the pedal into oscillation. Would reducing, or shorting, the 10K resistor in series with the wiper of the Repeats pot be a good way to achieve this?
merlinb
Yes that will do the trick. I remember that 8.2k was just enough to push it into oscillation, so you might start by paralleling a 39k resistor (10k||39k|| = 8k).
samhay
I dropped the value of the 10k in my build to ~ 7-8k (if I remember correctly), which gives almost-runaway repeats when the Repeats control is at max.
Note however that this won't quite accomplish everything the OP asked for as if you short this 10k with a second switch, but have the Repeats control at min, nothing much will happen. If you used a DPDT then you could switch something in parallel to the 10k with one half of the switch while simultaneously switching in a large resistance between lug 1 of the Repeats pot and ground (thus effectively turning the repeats pot all the way up).
merlinb
#3
Quote from: samhay on April 16, 2015, 09:21:19 AM
True. In fact, you might as well just change to the 10k resistor permanently to 8.2k or less. Then just lift the ground of the repeats pot  (with a large-ish resistor in parallel with the switch, as you said, to reduce pops).
Chugs
