What kind of switch is this, and could I use something else?
Started by Hav, April 27, 2015, 07:36:27 AM
Hav
Hi,
Need a bit of help here, I have a switch that needs repairing. It only has an 'On and Off' selection, but I cant seem to find a similar switch with 6 poles... there are all the standard ones with either 2 or 3 poles.
http://havsingh.com/Guitar/WhatIsThis/IMG_3898.JPG
http://havsingh.com/Guitar/WhatIsThis/IMG_3895.JPG
It says 3a 250v on the side too.
is this the right thing:
http://www.maplin.co.uk/p/dpdt-toggle-switch-fh39n
Thank you in advance!
antonis
Although your original switch is DPDT On-On, it's wired as On-Off so you can use the one with the on-off plate..
(or any DPST toggle switch..)
edit: I'm not sure if there is a short-circuit between the 2 other lugs but, if so, then you have to use a DPDT ON-ON switch... :icon_wink:
Your picture doesn't show a "6-pole" switch.  It's a DPDT - two (dual) poles, dual throw.  It has six terminals.  Think of it as two switches in one unit, each of which switches either "here" or "there".
The Maplin piece you reference is OK electronically, but it's physically much bigger than the one in your picture.  If you're really, really constrained to shop at Maplin, then this might be better.  BTW, ignore the 3A/250V markings - you're not switching mains (at least, I hope you're not switching mains!).
antonis
Mark, I edited the previous post because I think (can't see clear enough..) that there is a short-circuit at the "unused" lugs...
Hav
Thanks so much for the swift replies. The short on the unused poles are intentional. It's how I pulled it out the box... Popping down to maplin now (bit of a rush to get it solved otherwise would order online).
Hav
Quote from: antonis on April 27, 2015, 08:05:41 AM
Oh does this mean I can't buy an on - off switch?
antonis
Quote from: Hav on April 27, 2015, 08:42:43 AM
Only if the unused lugs were used...
(in reality, most of the ON-OFF switches are ON-ON with one of edge lug cut..) :icon_wink:
induction
Just to clarify what antonis said, if the 'unused' lugs are shorted, they're not really unused. It looks like it's wired is a normal bypass switch without input grounding. In one position the input jack goes to the circuit input and the output jack goes to the circuit output. In the other position, the input jack input goes to the output jack. If this is the case, then no, you can't use a DPST (on-off switch), you must use a DPDT on/on switch.
Note: Without a schematic, the above is just a guess. If the switch only has two positions, then it's probably correct. If the switch has 3 positions, then it's definitely not correct. The latter is unlikely, but not impossible. (Edit: Just noticed you said, "It only has an 'On and Off' selection") so I assume that means it's a two position switch. So a DPDT is the way to go.)
Hav
Ah that's fab. I bought the switch as suggested above. Thank you all for your help in the theory behind it too
